Backup Inclusion not working
NethServer Version: NethServer release 7.6.1810 (final)
I followed this instruction here http://docs.nethserver.org/en/v7/backup.html#inclusion to include /opt and /etc in our daily backup.
But when I was doing a test restoration, the /opt and /etc locations are not showing on the hierarchy.
Even tried to do a manual restore via putty, but same result.
Does the inclusion path needs to be under /etc/, for example /etc/postfix/ for the backup inclusion to work?
And I don’t need to issue any signal-event or expand-template command after modifying the custom.include file?
Thanks
There may be a missing or too many line breaks in the custom include file.
From the docs:
Make sure not to leave empty lines inside edited files.
Missing line break:
Hello MrMarkuz,
My custom.include looks like this now when I issue cat:
and mcedit looks like this:
I checked the restore files which does not show /opt and /etc folders and the other sub-folders for some reason even before modifying the custom.include file:
But it works on test manual restore via putty:
Thanks for your help.
