Authentication Issues with GHCR for NS8 Image (Even with Valid Token)
Dear NethServer Team,
I’m trying to properly authenticate with GHCR to use the NethServer Docker images in our CI/CD pipeline, but despite following the recommended steps, I keep getting DENIED: invalid token errors. Here’s what I’ve tried:
  1. Token Configuration:
  • Created new GitHub tokens with:
    • Only read:packages scope
    • Tried adding repo scope (for private repos)
  • Verified token length (40 chars) and no trailing spaces
  1. Test Commands:
# Returns DENIED error curl -H "Authorization: token ghp_***" https://ghcr.io/v2/nethserver/ns8/tags/list
# Docker login succeeds but pull fails echo "$GHCR_TOKEN" | docker login ghcr.io -u USER --password-stdin docker pull ghcr.io/nethserver/ns8:8.4 # manifest unknown
Key Questions:
  • Is the nethserver/ns8 image repository private? If so, what are the access requirements?
  • Are there special organization-level permissions needed?
  • Could you share a working example of CI/CD authentication?
… the context
I’m creating the documentation for a project approved by “El Sistema” for the presentation “Orchestrating the Educational Experience: Asset Management | Audiovisual Archive” where we used NethServer + Proxmox-VE as our fundamental node. I want to finish the documentation to share it with those who will help me implement it. Of course, I want to share it with this community, with much gratitude.
Happy times, everyone.
Hello Adrian,
thanks for sharing NS8!
Of course not! :wink:
All ns8 images are public including the repository that contains the code of the image.
Nope: you can pull the image without authentication.
I think the problem is that there is no image named ghcr.io/nethserver/ns8:8.4.
The version 8.4 is just a milestone name for a bunch of containers.
The core includes many containers like core, ldapproxy and many other.
To pull the only main core image, just execute:
docker pull ghcr.io/nethserver/core:3.9.0
Inside the testing CI, the requests are not authenticated.
The CI authenticates itself only when pushing new images.
This a workflow using Github CLI, but you do not need it for download:
export CR_PAT=$(gh auth token)
echo  $CR_PAT | podman login ghcr.io -u gsanchietti --password-stdin
podman pull ghcr.io/nethserver/ns8:8.4
If you want to know more, take a look to the install script.
What can I say, my friend?
Thank you very much!
I’ll share the publication soon.
All the best to you, Giacomo.
hello sir, any feedback in this, just came accross this, might be useful with module build automation testing.
