I’ve a seperate instance running only with OCS and remi php 7.4 as @stephdl in the wiki discribes.
Thank you for your work!!
Now a new version of OCS is available, but if I update to V 2.7 I get a blank page when entring OCS. In the console I see an error about favicon.ico not found.
Also there is a conflict with oniguruma and oniguruma5 from remi, but I could update NS to 7.8-2003 with excluding origuruma with a template custom.
Can you please take a look on that in the next time @stephdl?
No hurry. Just some time… Thanks in advance.
Hi Stephan, thanks for your reply. Hope you’re well in these times.
I disabled the ocs repo to stay with V 2.6. Is o.k. for me.
I do not need the latest version immediatly. I mostly wanted to warn others using OCS.
I did a snpshot before => rollback, nothing happend!
Yes, exactly. OCS is installed in /usr/share/ocsinventory-reports/ocsreports. I used your module.
I’ll setup a new VM to do some tests with OCS 2.7.
Honostly, I don’t know. But I think it’s not a problem of data delivery.
I think it’s a problem with http, because of the favicon.ico not found / http 1.1 404 error
