ARM development: next steps
Just did a quick test using curl, seems good:
curl 'http://mirrorlist.nethserver.org/?release=7&repo=ce-updates&arch=aarch64&nsrelease=7.6.1810'
curl 'http://mirrorlist.nethserver.org/?release=7&repo=ce-updates&arch=armhfp&nsrelease=7.6.1810'
it seems ok to me, for aarch64 and armhfp. tnx!
ops… i talked too early… i’ve done a full update, but now i got error on sclo which didn’t exist for aarch64
more tests, later…
Please give me the official URLs [or open a PR for them]!
This is from nethserver repo file:
[ce-sclo-sclo]
name=CE-SCLo-sclo-$nsrelease
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=ce-sclo-s$
#baseurl=http://mirror.centos.org/centos/$nsrelease/sclo/$basearch/sclo/
gpgcheck=1
repo_gpgcheck=0
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-SIG-SCLo
enabled=0
[ce-sclo-rh]
name=CE-SCLo-rh-$nsrelease
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=ce-sclo-r$
#baseurl=http://mirror.centos.org/centos/$nsrelease/sclo/$basearch/rh/
gpgcheck=1
repo_gpgcheck=0
enabled=0
Disabled it manually, like @dz00te said.
sorry I do not think I understood :thinking:
the problem is that ther is no official url… i mean if you check a mirrror:
http://dallas.tx.mirror.xygenhosting.com/centos-altarch/7.6.1810/sclo/aarch64/
only sclo-rh exixst for aarch64, while for armhfp there is no sclo* at all
i don’t know if it’s possible to manage this from mirrorlist (that will be probably the best solution), otherwise the only solution i see is to change
“/etc/e-smith/templates/etc/yum.repos.d/NethServer.repo/10base”
check the arch and and enable/disable [ce-sclo-sclo]
and [ce-sclo-rh] depending on the arch… but probably i miss something… :sweat_smile:
Yes, I forgot that …it’s the kind of input I need :smile:
IIRC packages that we recompile from EPEL and SCLo as dependencies for our modules will go to nethserver-updates/armhfp. Wherever an upstream mirror exists, mirrorlist will point to it.
Otherwise it could point to an empty/dummy repo and its packages are expected to be in nethserver-updates (or nethserver-base).
Yesterday I was able to install CentOS on a new Raspberry Pi4 2GB via this link:
https://www.centos.org/forums/viewtopic.php?f=49&t=71407&p=300229#p300246
After expanding the root partition I inserted the uSD into the Pi and was able to install NethServer:
yum install -y http://mirror.nethserver.org/nethserver/nethserver-release-7.rpm
nethserver-install
I had still some problems:
  • repo’s ce-sclo-sclo and ce-sclo-rh still had to be disabled manually; I don’t know the implication of this;
  • openVPN could not be installed;
  • rspamd as part of nethserver-mail-filter could not be installed.
What are the options to solve these problems?
You shouldn’t have any major drawbacks.
I have no idea on this.
I don’t know :slight_smile: The ARM project is community driven but it’s a little bit stuck.
Maybe @dz00te or other ARM users can help to solve your problems :slight_smile:
The rspamd rpm has been done manually by @mark_nl AFAIK, maybe he can upgrade the version or share his note to do it ourself ?
the last src.rpm I know is : http://packages.nethserver.org/nethserver/7/arm-base/Source/SPackages/rspamd-1.8.2-1.ns7.src.rpm
Installation of nethserver-mail-filter requires rspamd ≥ 1.9.1. I really have no idea how to upgrade this. @mark_nl can you point me in the right direction?
I hope the ARM project stays alive. Older Pi’s were not so powerfull; other boards were more powerfull, but I wasn’t able to install a recent version of Centos on it. I believe the new Pi4 will change this and might be a energy-saving server for soho-use.
I think it’s the same problem as with evebox, it’s not compiled for arm in the new version.
Perhaps @smutje1179 can help with compiling
well I can build locally rspamd for x86_64, probably more to know for ARM, wait and see
Thank @mark_nl for the spec file
Yes it could be, main restraint was the 1G ram with 2G or more it should perform much better!
@ftimmers give me a couple of days to update/(re)compile nethserver dependencies like rspamd for armhfp.
(Sorry for being a lousy community member…)
Thank a lot mark
Don’t worry. If you wanna come back to the party you’re welcome.
This is great! Many thanks in advance! Please take your time, I’m not in a hurry.
I got my hands on a rpi4 4G model, it on it’s way now…
For those interested they have one last in stock… (dutch webshop)
https://opencircuit.shop/Product/15270/Raspberry-Pi-4-Model-B-4GB
thanlk a lot for armhfp, what about for aarch64, do you have the hardware for this work ?
Yes, i use a odroid c2 or a scaleway vps (0.6 cent per hour or 2.99 per month) and it also possible to boot aarch64 on a rpi 3(+) :wink:
The usual workflow is build it for armhfp and then aarch64 is almost all times easy to do, so it will land a bit later in the repo’s
And meanwhile (Fedora) copr has aarch64 epel 7 as an build target :+1:
Still on the list to look in too…
Without further testing it did install oke over here, however it took an awful long time :cold_sweat:
Seems to be related to creation of certificates. From journalctl, note elapsed time 3:12
Aug 29 22:34:48 rpi4.havak.lan esmith::event[11266]: Using configuration from /var/lib/nethserver/certs/ca.cnf
Aug 29 22:38:00 rpi4.havak.lan esmith::event[11266]: Using CA Common Name: NethServer CA
crypto / entropy issue :thinking:
Rspamd 1.9.1-2 for armhfp is in testing (As you know from a PM…). Did minimal testing on it (installed and checked if it is running :hushed: )
