ARM development: next steps
I briefly searched for the yum-api solution, did not find one;
And as this involves python-session, I wonder if this straightforward if-then with a hardcoded basearch for arm 32bit is good enough?
IMO we have one necessary conditional in /usr/sbin/nethserver-install :hushed:
In short : some templates asume /usr/lib64 is present and on 32bit (armhfp) it is not.
also see: arm-dev/issues/26
This is my proposal:
Other small issue is the release status for each arch, I know it’s just optical and %post in specs are not liked so much… nevertheless my proposal is:
What do you think?
cc/ @davidep @dz00te @giacomo
I saw the patches and … :open_mouth:
Sorry but both are not acceptable, let’s find another solution! :wink:
Could you please post the list of affected templates? Let’s if we can add extra templates, if needed.
I don’t understand what is the problem here: can you make an example?
I am not sure if the list is complete, known to be affected:
Nethserver-squid:
/etc/e-smith/templates/etc/squid/squid.conf/20acl_10_auth line 13 and line 19
nethserver-openvpn:
/etc/e-smith/templates/etc/openvpn/host-to-net.conf/50security line 11
BTW credits to hunt this down go to @mrmarkuz here and here
put this ugly code in nethserver-sogo a long time ago to solve it
It is pure optical, howerver may throw up questions…
afbeelding
If we manage to synchronize the releases in the furture it can be dropped :grinning:
Really good catch!
I prefer the Sogo code rather than a link which could break the system.
Please open a new issue containing the problem for both packages: I will gladly help to fix the templates.
For now, let’s put the “Alpha”/“Beta” tag only inside the doc, I’d prefer to not change the code for such cosmetic issue.
Will do so …
Upfront: has PERL some (environment) variables which could be use full ?.. (like pseudo-code $ARCH)
Oke, at least I tried :grin:
I’ve found this: Config - access Perl configuration information - metacpan.org
But I don’t know if it is really good, I’d go with a simple file check
the WARING part is alarming.
Small code-style question, do you want me to comment “arm specific code” or not ?
I’d say only if the code is not self-explanatory. Probably in this case it could be useful to have it.
Modifications for Squid and OpenVPN are ready to be tested.
I also know that @Amygos did some good analysis on the Raspberry image and he found that Dedalo (Hotspot) works well!
He also pointed out another library path problem: https://github.com/NethServer/nethserver-firewall-base/blob/master/root/etc/e-smith/events/actions/interface-config-write-pppoe#L59
I think the fix can be the same of other cases.
Really thank you for the excellent work!
It’s holiday time here in Italy, I will be back on work January 7, but I will try to respond to any question during these couple of weeks!
hi all
I need some help
I do not have (yet) the hardware to test this on aarch64, please can you help here to verify the issues
others architectures are verified
You can use a KVM machine for that: yum install qemu-system-aarch64
Download the aarch iso from CentOS mirror: http://isoredirect.centos.org/altarch/7.6.1810/isos/aarch64/
Make sure to select aarch64 when creating the VM.
During install you will have time for a trip abroad: it’s very slow!
Thanx, will test it on aarch64 this affternoon
I would like to test a couple of issues inside an aarch64 machine, so I’ve created a new scaleway account.
But when creating a new machine, there is no CentOS image available for ARM.
What are the steps to have a running CentOS/NethServer aarch64 machine on Scaleway? Do I need to create my image?
Tested on virtual machine using qemu. Everything good.
Thank you @mark_nl!
i’m just playing a little with some ns76 altarch to see where we are, because i was a litle absent during last two months… anyway, i think that Ultimate ns7 software updates origin policy break yum on altarch
error on software center:
failure: repodata/repomd.xml from ce-base: [Errno 256] No more mirrors to try. http://mirror.centos.org/centos/7.6.1810/os/aarch64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
it seems that mirrorlist.nethserver.org did not handle correctly with altarch, ie if the ce-base seems to redirect to
but there is no such url
to make it work i have disabled from ce-* mirrorlist and changed baseurl, ie:
#baseurl=http://mirror.centos.org/centos/$nsrelease/extras/$basearch/
baseurl=http://mirror.centos.org/altarch/$nsrelease/extras/$basearch/
and i think we should also disable some repo for altarch:
ce-sclo* for armhfp
ce-sclo-sclo for aarch64
someone else had the same problem?
Thanks for reporting, we will look into it!
Seems like @Mr.Olie had the same problem:
Just pushed a fix to mirrorlist.nethserver.org, would you mind checking it out?
https://github.com/NethServer/mirrorlist/pull/22
