I am afraid this is not a problem about Intel/AMD.
The VPS host needs to support nested virtualization with virtualbox:
The virtualized arkcase in the virtualized Nethserver.
hmm. so what needs to happen in this case?
I tested in VMware, there you can just enable Intel VT/AMD V in cpu settings.
Iād try the following:
i think aruba support nested virtualization. they also use vmware⦠this is now tricky situation
Ill test multiple different variations and advise accordingly.
at this stag, what should be done exactly?
For example in proxmox you need to set to the VM cpu to āhostā.
To be able to reach the VM in bridged mode, you need to select the interface to bridge to. In my case (and in case you use AD that autocreates a bridge) this was br0. You can create a bridge in network settings.
What about just firing up a local VM for testing instead getting stuck in VPS setup?
If the app is good we can still think about different ways to integrate.
if its just a local vm for checking out the app, that i can try. Though i have hyper v, not sure if it works, or if i need to downlaod and install vmware or virtualbox.
As to why i wanted to install on vps, i am not sure why i prefer using that method than using local vm. I guess because of doing actual real scenario test
Did anyone ever succeed in making it run on VPS? I need to deploy it on azure.
@support_team
Did somebody test it?
am deploying local servers, ill test it on local once done
Hello, I would like just to mention that,
Taking into consideration that Laws and the handling of the Laws are very different from country to another,
And that NS and the Internet do exist because of the International nature of It,
I think we should think about a software suite that is able to handle this situation as much as possible,
For instance Dolibarr does handle different taxes rates and ways of handling it, if I remember ā¦
A āLaw/caseā software that suits only one jurisdiction is kinda of limiting and even unfair
I think .
Cheers
Hey guys Iām running Nethserver on a Virtual Dedicated Server I have 5 Vlan IPs (/29). I have installed Virtual Box instance of ArkCase using how to here I need to figure out how to add one of the additional public IPās to Nethserver and then config Virtual Box to access ArkCase. I have added a Vlan interface using one of the ipās set it to Green with the settings below. I tried setting the NetMask the same as the Red wan interface however nethserver would not allow it.
eno1.1
IP address
XXX.XXX.XXX.107
Netmask
255.255.255.0 (what should the Netmask be the main ip Netmask is 255.255.255.248)
Gateway
XXX.XXX.XXX.XXX
WAN (red) eno1 CIDR XXX.XXX.XXX.106/29
Netmask 255.255.255.248
Gateway XXX.XXX.XXX.105
Itās been a couple of years, and Iāll admit Iāve made some modifications to your instructions (mainly in moving the VirtualBox VM onto Proxmox), but hoping you might have an idea of whatās going on. In short, I canāt log in to ArkCase itselfāI get the 502 Proxy Error. Solr, Pentaho, and Alfresco are all running, and I can get to the front page of each of them. The arkcase service is running:
[root@arkcase-ce ~]# systemctl status arkcase
ā arkcase.service - ArkCase Service
Loaded: loaded (/etc/systemd/system/arkcase.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2022-11-06 09:28:10 GMT; 1 day 5h ago
Process: 12809 ExecStop=/opt/app/arkcase/bin/shutdown.sh -force (code=exited, status=0/SUCCESS)
Process: 12886 ExecStart=/opt/app/arkcase/bin/startup.sh (code=exited, status=0/SUCCESS)
Main PID: 12900 (java)
CGroup: /system.slice/arkcase.service
āā12900 /usr/bin/java -Djava.util.logging.config.file=/opt/app/arkcase/conf/logging.properties -Djava.util.logging.manager=org.ap...
Nov 06 09:28:10 arkcase-ce.local systemd[1]: Starting ArkCase Service...
Nov 06 09:28:10 arkcase-ce.local arkcase[12886]: Tomcat started.
Nov 06 09:28:10 arkcase-ce.local systemd[1]: Started ArkCase Service.
A Java process seems to be listening on port 8843:
[root@arkcase-ce conf.d]# netstat -tulpn | grep 8843
tcp 0 0 0.0.0.0:8843 0.0.0.0:* LISTEN 12900/java
ā¦but trying to connect directly to that gives āConnection refusedā, and browsing to https://IP/arkcase gives the aforementioned proxy error. I donāt see any log files in /var/log that seem relevant. Any ideas what I should be checking here?
i usally forget tht Danb is a lawyer.
hows arkcase been so far for you?
Unusable, as I posted above.
Iām going to try to reproduce but virtualbox is still downloading. How did you move the VM to proxmox?
I found following github issue about a similar error, explaining port 8843 and how to debug tomcat (last post):
Created a comparable-spec VM on the Proxmox host without storage, scp over the .vmdk file, imported it into the VM. It boots without issue, and Iām able to SSH in as vagrant/vagrant. But thanks for the pointer to that issueāthe troubleshooting steps there havenāt resolved the issue, but it looks like theyāre fairly engaged with the issue. Iāll see what I hear back from my comment.
Edit: Iād missed a step from that thread. Adding export HUSKY=0 to the end of /opt/app/arkcase/bin/setenv.sh lets arkcase start and Iām able to log in. Once I find the admin module and go to configure the email (naturally pointing to my Nethserver install), I get SMTP settings are not valid with no further information on where the problem is.
Has anyone (Martin? Markus?) got it working with Nethserver as the mail server? If so, what settings did you use? I should probably follow up with another ticket against the project, but if someone here knowsā¦
the last time i installed i think i used postal for email, though it sent, postal was not stable for Nethserver at the time, atleast now its abit stable on nethserver.
I can try and do a r-install of the solution over the weekend, when ill be testing other deployments as well.
Thanks, Iāll be interested if you can make it work (and if so, how). Iām not going to have much time to work on it in the coming week, but could get back to it after then. It sadly wonāt do much of anything for my own practiceāIām stuck with the system the Government providesābut itād be nice to play with it a bit anyway.
we built a custom solutions here, and many law firms locally are happy with it.
