**NethServer Version:7.5
**Module:Firewall
Hello,
I would like to activate function “Application Control” please recommend some steps
Thank you
**Module:Firewall
Hello,
Thank you
If I correctly understand you should install the nethserver-ndpi package.
From the doc :
http://docs.nethserver.org/en/v7/firewall.html#deep-packet-inspection-dpi
Thank you
Please mark the post as solved if is the case
So it mean, the Nethserver is NGFW, right ?
If you install the ndpi module I guess we can say so indeed.
Hello
How to block TeamViewer, YouTube, WhatsApp by using DPI ?
Set firewall rules and use as service DPI object like YouTube.
