*NethServer Version: 7.6.1810 *
Hi everyone, I noticed that anacron executes the job of the cron.daily .
In the log file I noticed the following:
After the set time, it runs but it seems to stop there![]()
After a short time this error appears:
This is the old correct operating screen that is executed in a short time
The content of the cron.daily is:
The cron spool has been left behind by one day.
Could you tell me where I can investigate the problem?
Thank you
I have just tested or temporarily deleted the 0yum-daily.cron file
I restarted anacrontab and the work started.
I noticed that this script is part of the yum-cron-3.4.3-161.el7.centos.noarch.rpm package
