Allowed networks in Reverse proxy do not work
Module: Reverse proxy
Not sure if i have setup this up correctly, but ik to have acccess to this reverse proxy domain from inside the :LAN.
I’ve put in the local IP in the Allowed networks field, but it is still accessable from outside the LAN
How can i set this up correctly ?
Thanks, it seems you found a bug, I can reproduce in NethSecurity 8-23.05.3-ns.1.1.0.
The “deny all” directive is missing in /etc/config/nginx after the allows in the config so everything is allowed. cc @giacomo
As a workaround you can edit /etc/config/nginx, search for the right proxy and add a deny line.
In the following example I allowed 192.168.3.0/24 for a reverse proxy via the UI before.
	list allow '192.168.3.0/24'
	list deny 'all'
Reload nginx
service nginx reload
Thanks for reporting, I’ve opened and issue: Host-based reverse proxy always accessible from all networks · Issue #723 · NethServer/nethsecurity · GitHub
The proposed workaround should work but the fix will be a little different.
