Again Problems after Updates
NethServer release 7.3.1611 (rc3)
During the Updates got Error messages that he could not finish Updates, clear yum etc.
After Clear yum again error with ndpi. After reboot again Error with ndpi. This is shown:
Deep Packet Inspection (DPI) module is not available
Restart the system and select a Linux kernel with DPI module support
And lost again the verification of my Users. The Domain is up and ready and shown without errors.
The Mysql is not started.
In the Overview it shows now only my Useraccounts, not the formerly ones. So i have only :
Benutzer
2
Benutzergruppen
3
eMail Adressen
2
Maschinenkonten
3
The Kernel what is used is the ony 4.4.22-1.e17.elrepo.x86-64
Any ideas or solutions?
Also see errors for Updates:
(2/10): base/7/x86_64/group_gz | 155 kB 00:00
epel/x86_64/updateinfo FAILED
https://mirror.imt-systems.com/epel/7/x86_64/repodata/69273bdf64c96c1b03fc923e6b682a7aa4ea85124e495a3806cc5ef6beafdc15-updateinfo.xml.bz2: [Errno 14] HTTPS Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below knowledge base article
epel/x86_64/primary_db FAILED
https://mirror.netcologne.de/fedora-epel/7/x86_64/repodata/2f2d8ee599b6d4f45a8f51537e0328bdd1ece4f0b7fc6b80e500c271bab5a706-primary.sqlite.xz: [Errno 14] HTTPS Error 404 - Not Found
Could this be related?
http://docs.nethserver.org/en/v7rc/release_notes.html#upgrading-rc2-to-rc3
To upgrade a system running kernel-lt with DPI support, execute these commands before updating:
[code]cat << EOF > /etc/sysconfig/kernel
UPDATEDEFAULT specifies if new-kernel-pkg should make
new kernels the default
UPDATEDEFAULT=yes
DEFAULTKERNEL specifies the default kernel package type
DEFAULTKERNEL=kernel
EOF
yum reinstall grubby -y[/code]
About the 404 error with epel mirrors it happens from time to time (not relevant if at the end it finds a working mirror).
i will check it
does not work
i have uninstall the Deep packet inspection (DPI) right now. But Problems with the Users are not gone. Not possible to log on with Sogo etc. I really appreciate the work from the guys here but if after every Update the mainstuff is not working is it very annoying.
I understand your frustration. Do you find any error message from sssd?
 journalctl -u sssd
Try again the leave/join procedure we issued some days ago!
have tried the leave and join procedure, dont work
in the journal -u sssd no errors
i also got errors during the updates i havent before:
If above article doesn’t help to resolve this issue please create a bug on https://bugs.centos.org/
(4/10): nethserver-updates/7/x86_64/group_gz | 16 kB 00:00:00
(5/10): base/7/x86_64/primary_db | 5.6 MB 00:00:00
(6/10): nethserver-updates/7/x86_64/primary_db | 2.1 kB 00:00:00
(7/10): epel/x86_64/updateinfo | 691 kB 00:00:00
(8/10): nethserver-base/7/x86_64/primary_db | 170 kB 00:00:00
https://mirror.imt-systems.com/epel/7/x86_64/repodata/2f2d8ee599b6d4f45a8f51537e0328bdd1ece4f0b7fc6b80e500c271bab5a706-primary.sqlite.xz: [Errno 14] HTTPS Error 404 - Not Found
(9/10): epel/x86_64/primary_db | 4.4 MB 00:00:00
(10/10): updates/7/x86_64/primary_db | 1.2 MB 00:00:01
Determining fastest mirrors
@hucky, quoting @dnutan above
Could you try
account-provider-test
Then
account-provider-test dump
[ERROR] cannot execute /usr/bin/ldapsearch. To workaround this type:
 yum install openldap-clients
[root@sbs ~]# account-provider-test dump
“startTls” : “”,
“bindUser” : “SBS$”,
“userDN” : “dc=compu-max,dc=lan”,
“port” : 636,
“isAD” : “1”,
“host” : “compu-max.lan”,
“groupDN” : “dc=compu-max,dc=lan”,
“isLdap” : “”,
“ldapURI” : “ldaps://compu-max.lan”,
“baseDN” : “dc=compu-max,dc=lan”,
“bindPassword” : “jBVl16OKR80OcZ”,
“bindDN” : “COMPU-MAX\SBS$”
Install and run again
[code][root@sbs ~]# account-provider-test
extended LDIF
LDAPv3
base <dc=compu-max,dc=lan> with scope baseObject
filter: (objectClass=*)
requesting: ALL
compu-max.lan
dn: DC=compu-max,DC=lan
objectClass: top
objectClass: domain
objectClass: domainDNS
instanceType: 5
whenCreated: 20161021112432.0Z
uSNCreated: 8
objectGUID:: 0Tg8os3xUkaL7V4KuMx8nQ==
objectSid:: AQQAAAAAAAUVAAAArgoFLfMkPOX9n/6b
objectCategory: CN=Domain-DNS,CN=Schema,CN=Configuration,DC=compu-max,DC=lan
dc: compu-max
auditingPolicy:: AAE=
creationTime: 131215226720000000
forceLogoff: -9223372036854775808
gPLink: [LDAP://CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=Syste
m,DC=compu-max,DC=lan;0]
isCriticalSystemObject: TRUE
lockoutDuration: -18000000000
lockOutObservationWindow: -18000000000
lockoutThreshold: 0
minPwdLength: 7
modifiedCount: 1
modifiedCountAtLastProm: 0
msDS-AllUsersTrustQuota: 1000
msDS-Behavior-Version: 4
ms-DS-MachineAccountQuota: 10
msDS-NcType: 0
msDS-PerUserTrustQuota: 1
msDS-PerUserTrustTombstonesQuota: 10
nextRid: 1000
nTMixedDomain: 0
oEMInformation: Provisioned by SAMBA 4.4.5
pwdProperties: 1
pwdHistoryLength: 24
serverState: 1
systemFlags: -1946157056
uASCompat: 1
rIDManagerReference: CN=RID Manager$,CN=System,DC=compu-max,DC=lan
wellKnownObjects: B:32:6227F0AF1FC2410D8E3BB10615BB5B0F:CN=NTDS Quotas,DC=comp
u-max,DC=lan
wellKnownObjects: B:32:F4BE92A4C777485E878E9421D53087DB:CN=Microsoft,CN=Progra
m Data,DC=compu-max,DC=lan
wellKnownObjects: B:32:09460C08AE1E4A4EA0F64AEE7DAA1E5A:CN=Program Data,DC=com
pu-max,DC=lan
wellKnownObjects: B:32:22B70C67D56E4EFB91E9300FCA3DC1AA:CN=ForeignSecurityPrin
cipals,DC=compu-max,DC=lan
wellKnownObjects: B:32:18E2EA80684F11D2B9AA00C04F79F805:CN=Deleted Objects,DC=
compu-max,DC=lan
wellKnownObjects: B:32:2FBAC1870ADE11D297C400C04FD8D5CD:CN=Infrastructure,DC=c
ompu-max,DC=lan
wellKnownObjects: B:32:AB8153B7768811D1ADED00C04FD8D5CD:CN=LostAndFound,DC=com
pu-max,DC=lan
wellKnownObjects: B:32:AB1D30F3768811D1ADED00C04FD8D5CD:CN=System,DC=compu-max
,DC=lan
wellKnownObjects: B:32:A361B2FFFFD211D1AA4B00C04FD7D83A:OU=Domain Controllers,
DC=compu-max,DC=lan
wellKnownObjects: B:32:AA312825768811D1ADED00C04FD8D5CD:CN=Computers,DC=compu-
max,DC=lan
wellKnownObjects: B:32:A9D1CA15768811D1ADED00C04FD8D5CD:CN=Users,DC=compu-max,
DC=lan
fSMORoleOwner: CN=NTDS Settings,CN=NSDC-SBS,CN=Servers,CN=Default-First-Site-N
ame,CN=Sites,CN=Configuration,DC=compu-max,DC=lan
msDs-masteredBy: CN=NTDS Settings,CN=NSDC-SBS,CN=Servers,CN=Default-First-Site
-Name,CN=Sites,CN=Configuration,DC=compu-max,DC=lan
msDS-IsDomainFor: CN=NTDS Settings,CN=NSDC-SBS,CN=Servers,CN=Default-First-Sit
e-Name,CN=Sites,CN=Configuration,DC=compu-max,DC=lan
masteredBy: CN=NTDS Settings,CN=NSDC-SBS,CN=Servers,CN=Default-First-Site-Name
minPwdAge: 0
maxPwdAge: -9223372036854775808
whenChanged: 20161021112639.0Z
uSNChanged: 3732
distinguishedName: DC=compu-max,DC=lan
search result
search: 2
result: 0 Success
numResponses: 2
numEntries: 1
“startTls” : “”,
“port” : 636,
“isAD” : “1”,
“isLdap” : “”,
“bindDN” : “COMPU-MAX\SBS$”[/code]
nothing changed.
Some other commands, just trying to understand where is the problem:
 id admin
 id administrator
 net ads info
 net ads testjoin
 /usr/libexec/nethserver/list-users
 net ads search -P samaccountname=administrator
Then
 kinit administrator@compu-max.lan
everything get ok´s without an error but the kinit respond:
KDC reply did not match expectations while getting initial credentials
this really makes me upset. it is the third time i only install the updates what comes with the softwarecenter and after it something is broken :frowning:
Don’t be upset, we’ll find a solution. Let’s see
 cat /etc/resolv.conf
It could be mangled… Then try fix
 signal-event nethserver-dnsmasq-save
And kinit again
also everything ok with cat /etc/resolv.conf
after kinit same problem
