Hello everyone, I wanted to integrate on the Nethserver server, a program that allows me to manage orders, quotes, which clearly integrates with the LDAP system. Thank you
Well, Wordpress has the WooCommerce plugin, and that would handle orders and such, but I don’t think it integrates with LDAP.
Thank you for responding, but is there an app that can be installed under /var/www/html?
dolibarr (CRM/ERP)?
I wanted to tell you that trying dolibarr I found the form I needed. Thank you for your suggestion
