pk198105
(Pk198105)
April 20, 2020, 10:24pm
1
NethServer Version: 7.7.1908
Module: File Server 4.5.3
I recently added a new 1TB drive to my nethserver and would like to use that as my samba shared folders drive.
I already have 3 shared folders in /var/lib/nethserver/ibay/ but that folder is on my /dev/sda2 my new drive and partition is on /dev/sdc/
I tried editing /etc/samba/smb.conf but the file says not to update it since it will be regenerated
Can someone help please?
Hi & Welcome to the NethServer community!
The easiest way would be to create the shares needed in the cockpit / server-manager, than move over your shares (folders), then make a symlink pointing to your new disk in /var/lib/nethserver/ibays…
pk198105
(Pk198105)
April 20, 2020, 11:08pm
3
wouldnt moving the shares cause permission issues? also how would moving the folder affect the cockpit/server-manager.
Is there a guide on how to accomplish this?
Thanks ffor the quick answer btw
@pk198105
It shouldn’t affect either cockpit or server manager…
Use mv to move the shares. Perms should stay the same. (It’s still the same server, drive is also mounted under / somewhere…
I’ve used this very often, never had issues.
My 2 cents.
pk198105
(Pk198105)
April 20, 2020, 11:29pm
5
Thank you I will give it a try with dummy folder
Again thanks for the help
Always a good idea, also a backup or snapshot, if running virtual, is also always a good idea
pk198105
(Pk198105)
April 21, 2020, 4:32am
7
It worked thank you so much!
@pk198105
Welcome!
PS: Add in Solution (you’re the opener of this post/problem…) to your Post on top, so others with a similiar problem can find & solve their problem…
Now we have an amazing feature on our community platform which helps to mark a topic as SOLVED
As the OP (topic creator) you will have a button that allows you to accept an answer
[image]
Accepted answers are highlighted in the topic list:
[image]
Accepted answers are highlighted on the initial topic:
[image]
This kind of action is enabled only for topic into the Support category
Happy support!
Thx
EddieA
(Eddie Atherton)
April 21, 2020, 4:53am
9
Also, once you have mounted the drive, you can use the UI to reset all the permissions to match what you set for the share.
Also you are not moving the shares. You are just creating a link from the ibay to the mounted disk.
Cheers.
