Hi, I’m using Nethsecurity 8.8.0 and I have a few implementation requests.
The ability to add domains to certificates without having to delete and recreate the certificate every time.
The ability to set up a reverse proxy for a www domain, as this is currently not possible because it returns a 502 error.
I was able to perform the procedures described above using the `uci` command, for example:
uci add_list acme.domainname.domains=‘my.domain.com'
As for the www redirect, I did it this way:
uci del nginx.ns_ID.include
uci set nginx.ns_8c37f53e.return='301 https://my.domain.com$request_uri'
Perhaps it would be interesting to be able to perform these fairly standard procedures directly from the GUI in future versions.
Thank you very much
