NethServer Version: NS8
Module: WebServer
Hi all,
it’s possible to add the imagick module to ns8-webserver?
Can you help me?
Thank you in advance!
Module: WebServer
Hi all,
Can you help me?
cc @stephdl
please explain why you need it, what you want to do, it could help others to understand and offer the better answer
I installed WordPress and in the health site section, the system tells me that imagick is missing
coming soon
Hi @stephdl
Installed 1.3.1-dev3: imagick is ok (error is gone), but I get CA error again
ca-certificates is still inside the container ?, install again to see ?
It seems not installed:
root@webserver:/var/www/html# dpkg -l | grep ca-certificates
1.3.1-dev4 is coming
Now it’s fine. Imagick and CA are working!
ii ca-certificates 20230311+deb12u1 all Common CA certificates
