NethServer Version: 7.9.2009
Module: Threat shield
Hi, I’m having some difficulties trying to add a custom ipset to Threat shield.
So far, I’ve added the git url (https://github.com/firehol/blocklist-ipsets), raised MaxElem property and enabled some categories.
I wanted to use a custom blacklist with several IP address related to VPNs which I haven’t found in any of the included categories. I added a text file with these addresses to /usr/share/nethserver-blacklists/ipsets, using the same format as other ipsets. After that I can see the new category as available in cockpit, but when I enable it I get and error and shorewall-update fails.
From what I’ve seen, my ipset has been removed from the directory and shorewall fails to load the ipset. I had to disable and re-enable some random category to solve the problem.
I’m I doing something wrong or should I use another method to add a custom ipset?
