Lo0k3r
(Claudio)
1
Module: Nextcloud 1.5.0
Hello,
I’m using Nethserver 8 with Nextcloud, as I see the traefik ingress under http route is locked,
i was wondering how I can upload and use a custom certificate on the NextCloud endpoint?
also, is possible to enable Nextcloud also without https?
Thank you
mrmarkuz
(Markus Neuberger)
2
Yes, you can upload a certificate on the TLS settings page, see TLS certificates — NS8 documentation
If you like to upload a self-signed one, see ns8-traefik/README.md at main · NethServer/ns8-traefik · GitHub how to disable the verification.
No, the login doesn’t work without https.
