Add a VPN account in Nethsecurity not possible
Hostname NethSec8
Release NethSecurity 8 23.05.3-ns.1.0.0
I’ve registered the system with a trial subscription, but i’m not able to a VPN account
What am i doing wrong ? Or is this not working wth a trial account
  • May 23 12:02:50 NethSec8 openvpn(ns_roadwarrior1)[4460]: MANAGEMENT: Client connected from /var/run/openvpn_ns_roadwarrior1.socket
  • May 23 12:02:50 NethSec8 openvpn(ns_roadwarrior1)[4460]: MANAGEMENT: CMD ‘status 3’
  • May 23 12:02:50 NethSec8 openvpn(ns_roadwarrior1)[4460]: MANAGEMENT: Client disconnected
  • May 23 12:02:53 NethSec8 : DIGEST-MD5 common mech free
I believe not too much. Searching Google (Bing and DuckDuck are down) on:
“OpenVPN MANAGEMENT: CMD ‘status 3” provides some results. May this helps (altho it is status 2)
HTH
Does the ClearOS database is associated to the Road Warrior server?
You can use the trial: the trial has no limitation.
This log is not relevant: it’s the UI that tries to query the OpenVPN server to list connected users.
I’m not sure. How can i see this ?
I’ve connect the ClearOS LDAP server with Nethsecurity and i see a list of the users.
Do i need to do more ?
You choose the database during OpenVPN server creation, under the User database field: OpenVPN Road Warrior — NethSecurity documentation.
If you selected the wrong one, you must delete and re-create the OpenVPN server.
You can see the currently connected database from the main OpenVPN road warrior page:
Look at the Database label.
Ah… Stupid of me
It was still on the other database.
Thanks !!
Not stupid at all!
Maybe we should add the name of the connected database also inside the drawer :thinking:
