Hi pals,
I am experimenting some issues with adagios. When I open the adagios web applications I get the follow problem:
**ParserError: "[Errno 2] No such file or directory while connecting to '/var/spool/nagios/cmd/livestatus'. Make sure nagios is running and mk_livestatus loaded."**
and the show debug informations is at follows:
File "/usr/lib/python2.7/site-packages/adagios/views.py", line 43, in wrapper
result = view_func(request, *args, **kwargs)
File "/usr/lib/python2.7/site-packages/adagios/status/views.py", line 650, in status_index
c = adagios.status.utils.get_statistics(request)
File "/usr/lib/python2.7/site-packages/adagios/status/utils.py", line 454, in get_statistics
*arguments
File "/usr/lib/python2.7/site-packages/pynag/Parsers/livestatus.py", line 1116, in get_services
return self.query('GET services', *args, **kwargs)
File "/usr/lib/python2.7/site-packages/pynag/Parsers/multisite.py", line 80, in query
query_result = backend_instance.query(query, *args, **kwargs)
File "/usr/lib/python2.7/site-packages/pynag/Parsers/livestatus.py", line 973, in query
livestatus_response = self.write(livestatus_query.get_query())
File "/usr/lib/python2.7/site-packages/pynag/Parsers/livestatus.py", line 820, in write
livestatus_socket = self._get_socket()
File "/usr/lib/python2.7/site-packages/pynag/Parsers/livestatus.py", line 804, in _get_socket
raise ParserError(msg % (e, self.livestatus_socket_path))
Does anybody get the same issue??
Cheers
