ActiveSync with Nextcloud
I‘m wondering if it‘s possible to get activesync working with nextcloud. As Sogo does not offer DAV for the storage and sync of files I‘m using nextcloud. I just don‘t want to use two different backends for Calendar/Contacts and FileSync as I like to have all in one place
Regards
Joachim
Some Nextcloud users tried to make it work through z-push:
IIRC Webtop supports active-sync (z-push) and has integration for Nextcloud and some cloud services. I’m unsure about DAV storage.
Thank you Marc,
I‘ll try it as soon I‘m back home and post the result here.
