NethServer Version: 7.4.1768 final
Module: webtop5
Hi, sorry for my bad english.
I have a fresh install of nethserver.
I install webtop5 module. If i connect to the web server, the user is ok.
I need to configure outlook 2016 with EAS. But when i connect, outlook say bad username or password ?
I wrote the same username as the web server.
If i install Sogo and uninstall webtop, i have the same problem.
Have you an idea of the problem ?
Thank for your help !
