Active Directory Ports - NethServer IP or AD Container IP?
Microsoft page with defined ports needed for common Active Directory related ports needed for proper communication and domain join. https://support.microsoft.com/en-us/help/179442/how-to-configure-a-firewall-for-domains-and-trusts
Question: When adding new rules to our network firewalls on our internal LAN, what IP are we targeting here with the way NethServer runs AD in a separate container with it’s own IP?
Do we use NethServer VM IP for all ports?
AD container IP for all?
Mixture of both depending on the ports?
The Nethserver (domain member) uses following ports:
https://wiki.samba.org/index.php/Samba_Domain_Member_Port_Usage
For the AD container:
https://wiki.samba.org/index.php/Samba_AD_DC_Port_Usage
Awesome! Thanks Markus
To the NethServer website admin or other project devs, these links should go in official how to docs or the manual somewhere. (Unless it is somewhere that I didn’t find)
You’re welcome. If you like to contribute:
Please mark the topic as solved:
