Hi, I’m using an old version of nethserver 6.10 constantly updated and Samba version 3.6.23-53.el6_10
I have an issue with SMB protocol still at Version 1.
I tried to put in smb.conf global
min protocol = SMB2
but it doesn’t work.
There’s is a way to let SMB work with protocol 2 ?
@giacomo am i wrong calling for “configuration fragment” here?
@enrilor CentOS 6 (base for NethServer 6) is out of support since December 2020. Therefore… migration could be an important step for have almost 3 years of security updates.
Then edit /etc/e-smith/templates-custom/etc/smb.conf/10global, finally apply the config: signal-event nethserver-samba-update.
I do not have an old NS 6 installed, but you could look to man smb.conf to find the correct option.
May be you search for server min protocol and server max protocol.
