I took the risk to lose the share but after the reinstallation it is still there…
The GUI told me that everything is fine:
but I found some errors in the log:
May 13 08:54:24 neth13 systemd: Started System Security Services Daemon.
May 13 08:54:24 neth13 realmd: * /usr/bin/sh -c /usr/sbin/authconfig --update --enablesssd --enablesssdauth --enablemkhomedir --nostart && / usr/bin/systemctl enable oddjobd.service && /usr/bin/systemctl start oddjobd.service
May 13 08:54:25 neth13 sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Min or = Server not found in Kerberos database.
May 13 08:54:26 neth13 sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Min or = Server not found in Kerberos database.
May 13 08:54:26 neth13 systemd: Reloading.
May 13 08:54:26 neth13 realmd: * Successfully enrolled machine in realm
May 13 08:55:24 neth13 esmith::event[5390]: expanding /etc/shorewall/snat
May 13 08:55:24 neth13 esmith::event[5390]: Action: /etc/e-smith/events/actions/generic_template_expand SUCCESS [3.076049]
May 13 08:55:24 neth13 systemd: Reloading.
May 13 08:55:27 neth13 kernel: nf_log: can't load ipt_ULOG, conflicting nfnetlink_log already loaded
May 13 08:55:27 neth13 kernel: ipt_ULOG: ULOG: fail to register logger.
May 13 08:55:28 neth13 kernel: nf_log: can't load ipt_ULOG, conflicting nfnetlink_log already loaded
May 13 08:55:28 neth13 kernel: ipt_ULOG: ULOG: fail to register logger.
[root@neth13 ~]# journalctl -u sssd | grep 'tkey query'
May 13 08:54:25 neth13.mydomain.at sssd[4660]: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
May 13 08:54:26 neth13.mydomain.at sssd[4660]: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
May 13 08:54:43 neth13.mydomain.at sssd[4809]: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
May 13 08:54:44 neth13.mydomain.at sssd[4809]: tkey query failed: GSSAPI error: Major = Unspecified GSS failure. Minor code may provide more information, Minor = Server not found in Kerberos database.
