NethServer Version: 7.9.2009
Module: SOGo
I’m currently evaluating NethServer and running into some issues with shared mail folders.
One issue is mentioned here:
All users cannot access the shared mailbox folder, the error message is 'An error occured while communicating with the mail server".
Furthermore, when a user shares a personal folder with another user this folder does not show up in the other user’s browser.
I assume both issues are part of the same permisson problem.
sogo.log:
Apr 24 16:25:00 sogod [2079]: [ERROR] <0x0x55ffdd6cb6a0[NGImap4Connection]> could not select URL: imap://admin%40domain.com@localhost/Public/?tls=NO&tlsVerifyMode=default: {RawResponse = “{ResponseResult = {description = " Permission denied (0.001 + 0.000 secs).”; flag = NOPERM; result = no; tagId = 9; }; }"; access = NOPERM; reason = " Permission denied (0.001 + 0.000 secs)."; result = 0; }
Apr 24 16:25:00 sogod [2079]: 192.168.0.20, 192.168.0.223 “POST /SOGo/so/admin/Mail/0/folderPublic/view HTTP/1.1” 500 72/48 0.366 - - 0 - 15
Is there any structural solution to this problem? Suggestions in other posts do not work. It looks like it’s been around for quite a while. I really need to have this fixed since most user over here make a lot of use of shared (personal) mail folders.
Note: when I create a public mailbox and set ACLs all users can access this mailbox. It’s just that personal shared mail folders don’t end up in the Shared Mailbox section. Is there any way to set permissions on the top level?
Thanks,
Dave
