Hi all
I want to access host is on the lan Side of the Nethserver Firewall from a laptop is connect on AP on the Wan Side of the firewall
Firewall
LAN: 192.168.100.1
WAN: 192.168.0.2 GW: 192.168.0.1
What i need to configure on firewall to access from the laptop to the host in LAN?
Thanks you
mrmarkuz
(Markus Neuberger)
February 21, 2022, 9:34pm
2
It depends on what you want to access.
There’s port forwarding (access port(s)), reverse proxy (access a website) and vpn (full access) to reach internal devices.
Hi @mrmarkuz
I need to use a printer for print and for the moment anything else, so i thinking port forwarding is the better way in this case…
I don’t know which ports i need to open maybe i can use tcpdump to see it and open only i needed, otherwise i open all ports 1:65535
kelevra
(Евгений Копьев)
February 22, 2022, 9:05am
4
Don’t even think about opening the printer ports to the outside. In this case, it is better to use a VPN.
mrmarkuz
(Markus Neuberger)
February 22, 2022, 12:50pm
7
Denis_Pollini:
I use OpenVPN
Which printer do you use? Which OS do you use on the laptop?
Can you ping the printer by name/ip from the laptop when connected to openvpn?
@mrmarkuz
Hi i have fix the problem with OpenVPN
Thanks you
mrmarkuz
(Markus Neuberger)
February 23, 2022, 10:30am
9
You’re welcome. If a problem is fixed please mark the posting that helped you as solution. This way we know an issue is solved and other users can find the solution easily.
Now we have an amazing feature on our community platform which helps to mark a topic as SOLVED
As the OP (topic creator) you will have a button that allows you to accept an answer
[image]
Accepted answers are highlighted in the topic list:
[image]
Accepted answers are highlighted on the initial topic:
[image]
This kind of action is enabled only for topic into the Support category
Happy support!
