I also see topics like using hotsync as backup strategy (what I don’t think is the best way to backup) but it could be a way to fastly move a server from one location to another. without dealing with the hardware too much.
My situation: I have a several VPS’s running NS7. These VPS’s all have proxmox as hypervisor and I have access to both SSH as VNC with root privileges.
What if I create a similar VM on my personal ProxMox environment, and do a hotsync, would I end up with a complete ‘copy’ of the original server and have the original server still in place, working as it is supposed to be?
It would be a nice extra, expecially when going from 1 spec server to another… (create the specs of the old VPS, do a hotsync, adapt the hotsync to the new specs and hotsync back to the new VPS with new specs)
I don’t think that this is completely true. Not every module ist supported by hotsync.
If you want hotsync to sync custom paths, you have to tell it in /etc/hotsync.d/ with a file like I did for my urbackups called urbackup.sh and make it executable:
#!/bin/bash
# This file includes urbackup into hotsync
# R. Jeckel 15.04.2021
# source configuration file
[ -f /etc/hotsync.conf ] && source /etc/hotsync.conf
INCLUDE_FILE=$1
EXCLUDE_FILE=$2
# ceck if urbackup is installed
if rpm -q --quiet nethserver-urbackup; then
# include urbackup directories
echo /var/lib/urbackup >> $INCLUDE_FILE
fi
