Hi Guys!
so between the work and the use of the asylum seekers, I have changed my little server to 6.7.
Except for one little thing everything is wonderful!
It does not work the spam filter, I I’ve installed as identical with the ‘old’ 6.6 configuration, the virus scanner works and carries his Ergbnis in the message, the spam filter does nothing.
Is this a known problem ???
Here the source of a test email:
Return-Path: gerald.musch@thwfs.de
Delivered-To: gerald@openzwo.nandlnet.lan
Received: from openzwo.nandlnet.lan
by openzwo.nandlnet.lan (Dovecot) with LMTP id +7+TNoanHlYWEAAAMpIXEw
for gerald@openzwo.nandlnet.lan; Wed, 14 Oct 2015 21:05:42 +0200
Received: from localhost (localhost [127.0.0.1])
by openzwo.nandlnet.lan (Postfix) with ESMTP id BE4C33400B6
for gerald.musch@nandlnet.de; Wed, 14 Oct 2015 21:05:42 +0200 (CEST)
X-Virus-Scanned: amavisd-new at openzwo.nandlnet.lan
Received: from openzwo.nandlnet.lan ([127.0.0.1])
by localhost (openzwo.nandlnet.lan [127.0.0.1]) (amavisd-new, port 10024)
with ESMTP id lKX9vU284UGR for gerald.musch@nandlnet.de;
Wed, 14 Oct 2015 21:05:41 +0200 (CEST)
Received: from mo4-p00-ob.smtp.rzone.de (mo4-p00-ob.smtp.rzone.de [81.169.146.163])
by openzwo.nandlnet.lan (Postfix) with ESMTPS
for gerald.musch@nandlnet.de; Wed, 14 Oct 2015 21:05:41 +0200 (CEST)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; t=1444849540; l=252;
s=domk; d=thwfs.de;
h=Content-Transfer-Encoding:Content-Type:MIME-Version:To:From:Subject:
Date;
bh=U2rIF5DSqSb3dHnhfnfrCjgEvV4IJGGLJZG2Fi2IVzw=;
b=CS3dGkAJR2nsSeODc+QXLlbEFWj7DwfT6jIPZji9yx8fxnbJTWUtDIjP8Uzlrr88ij6
g5taXYsKeRVOgObvOrrHgVbb3cSdKRqnmLGv9+EmvOd/LQKCIhg9Vh2h39lWhllzt8o2Z
sthFCCqLAK0RJS+jwcSElFdnFzFrcP2gHsQ=
X-RZG-AUTH: :K2kWdEysNfKguCMZB1GmP0phWE6J2QaBspxRhAWAD0JydiXFn/7u1UmuL6/H
Message-ID: V03897r9EJ5e95G.RZmta@mo4-p00-ob.smtp.rzone.de
X-RZG-CLASS-ID: mo00
Received: from [10.83.203.184] (ip-109-43-0-52.web.vodafone.de [109.43.0.52])
by smtp.strato.de (RZmta 37.14 DYNA|AUTH)
with ESMTPSA id V03897r9EJ5e95G
(using TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (curve secp521r1 with 521 ECDH bits, eq. 15360 bits RSA))
(Client did not present a certificate)
Wed, 14 Oct 2015 21:05:40 +0200 (CEST)
Date: Wed, 14 Oct 2015 21:05:38 +0200
Subject: T2105
To: “gerald.musch” gerald.musch@nandlnet.de
MIME-Version: 1.0
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: base64
CgpHZXJhbGQgTXVzY2gKRmFjaGJlcmF0ZXIKKDAxNTIpNTMxMTUyMDkKCkJ1bmRlc2Fuc3RhbHQg
VGVjaG5pc2NoZXMgSGlsZnN3ZXJrCk9ydHN2ZXJiYW5kIEZyZWlzaW5nClNvbmRlcm3DvGxsZXJ3
ZWcgMTIKODUzNTQgRnJlaXNpbmcKVGVsZWZvbiAoMDgxNjEpNzQ4OApodHRwOi8vd3d3LnRody1m
cmVpc2luZy5kZQ==
and here are the setting in the Mail area:
Thank you for your help!!!
Gerald
