Vhost not visible from outside
I have a problem. If I create a virtual host, then the locally operating without error. From the outside it does not work. Here nethserver home page is displayed.
What else should I set?
If local:
If ext:
Thanks
Jeno
Is the Allow access from trusted networks only unchecked for that virtualhost?
If it is already unchecked, can you share your settings? (hiding ftp password if set, of course)
Thank you, I did not notice this.
