capote
(Marko)
March 8, 2018, 11:28am
1
Hello again,
I have another technical question. Maybe you could help me. I originally asked the support category, but I’m not sure if you are aware of it. Therefore, here is a separate reference with the request to also consider it.
best regards, Konrad
NethServer Version: 7.4 ELPRO-Kernel
Hello, next question…
On my local Macs I use a long time unbound as a local DNS-resolver without forwarding and “qname-minimisation: yes” . Also I got a DNSSEC-Solution by the way!
On my last attempt the to implement a gateway I used IPFirewall (with kernel 2.x tooo slow). They provide unbound by default, but with forwarding. A charming feature is the possibility to block web pages on DNS level and therefore you don’t need a webproxy. To do this I used th…
Source: Unbound DNS Server Tutorial @ Calomel.org
Sorry man but I didn’t get why you opened a new topic.
Is there a specific reason?
capote
(Marko)
March 8, 2018, 5:47pm
3
I tought there is any impact to choose the wrong/right catagory.
It’s now obsolete.
Sorry, Konrad
