The install/update may have failed due to metadata caching issues. Please clean the cache by clicking the button below and retry the install/update operation."
Tried to press the Clear Yum Cache with no success.
Any ideas ?
Your repo file starts with a blank line or is missing some content. As said by @pike, look at the file content. You might have to remove the blank line or recreate the file.
If I’m not wrong, yum checks all the repos to build the cache. The error refers to that repo file so it seems the file could have been corrupted. If you post the content of that file we can see what’s wrong.
The file contents are wrong. It seems when you used curl to download the repo file it failed to find it (maybe a missing letter or something of that sort).
If you are using Microsoft SQL Server, you can recreate it as instructed above.
It should look like:
rm -f /var/lib/rpm/__db
rm -f /etc/yum.repos.d/mssql-server.repo
db_verify /var/lib/rpm/Packages
rpm --rebuilddb
rm -rf /var/cache/yum
clicked the red banner in the GUI
checked SQL status and it’s running so maybe there was a double configuration in some way
