still in development, a tip, when you learnt something, never stop, it is so hard to restart
I have a minor issue I need time to understand…why a teaser, now I cannot go back
Whoah!
For me, it’s a killing feature.
No need anymore to juggle with the browser and webssh on the ipad
Pretty cool! Can’t wait to see it.
If you have vim, mock, some vm, nothing is impossible.
@davidep @giacomo I have an issue with the sysvinit script of shellinabox, it does a hang when I do the event nethserver-shellinabox-update
the sysvinitscript : https://gist.github.com/stephdl/a0bfdfa522753774a14c
my event nethserver-shellinabox-update
# ls -la -R /etc/e-smith/events/nethserver-shellinabox-update/
/etc/e-smith/events/nethserver-shellinabox-update/:
total 16
drwxr-xr-x. 4 root root 4096 Oct 18 15:26 .
drwxr-xr-x. 56 root root 4096 Oct 18 13:27 ..
lrwxrwxrwx. 1 root root 39 Oct 18 15:26 S00initialize-default-databases -> ../actions/initialize-default-databases
drwxr-xr-x. 2 root root 4096 Oct 18 15:26 services2adjust
drwxr-xr-x. 3 root root 4096 Oct 18 13:27 templates2expand
/etc/e-smith/events/nethserver-shellinabox-update/services2adjust:
total 8
drwxr-xr-x. 2 root root 4096 Oct 18 15:26 .
drwxr-xr-x. 4 root root 4096 Oct 18 15:26 ..
lrwxrwxrwx. 1 root root 6 Oct 18 15:26 httpd -> reload
lrwxrwxrwx. 1 root root 7 Oct 18 15:26 shellinaboxd -> restart
/etc/e-smith/events/nethserver-shellinabox-update/templates2expand:
total 12
drwxr-xr-x. 3 root root 4096 Oct 18 13:27 .
drwxr-xr-x. 4 root root 4096 Oct 18 13:27 etc
/etc/e-smith/events/nethserver-shellinabox-update/templates2expand/etc:
total 16
drwxr-xr-x. 4 root root 4096 Oct 18 13:27 .
drwxr-xr-x. 3 root root 4096 Oct 18 13:27 ..
drwxr-xr-x. 3 root root 4096 Oct 18 13:27 httpd
drwxr-xr-x. 2 root root 4096 Oct 18 15:26 sysconfig
/etc/e-smith/events/nethserver-shellinabox-update/templates2expand/etc/httpd:
total 12
drwxr-xr-x. 4 root root 4096 Oct 18 13:27 ..
drwxr-xr-x. 2 root root 4096 Oct 18 15:26 conf.d
/etc/e-smith/events/nethserver-shellinabox-update/templates2expand/etc/httpd/conf.d:
total 8
-rw-r--r--. 1 root root 0 Oct 18 13:27 shellinabox.conf
/etc/e-smith/events/nethserver-shellinabox-update/templates2expand/etc/sysconfig:
total 8
-rw-r--r--. 1 root root 0 Oct 18 13:27 shellinaboxd
the createlinks
#!/usr/bin/perl -w
use esmith::Build::CreateLinks qw(:all);
my $event = 'nethserver-shellinabox-update';
# templates to expand
foreach my $event (qw ( nethserver-shellinabox-update nethserver-shellinabox-save)) {
templates2events("/etc/sysconfig/shellinaboxd", $event);
templates2events('/etc/httpd/conf.d/shellinabox.conf', $event);
# services to launch on event
event_services($event,
'httpd' => 'reload',
'shellinaboxd' => 'restart');
# actions to do
event_actions($event,
'initialize-default-databases' => '00');
my $event = 'nethserver-shellinabox-save';
'runlevel-adjust' => '99',
'firewall-adjust' => '70');
exit
/var/log/messages
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Event: nethserver-shellinabox-update
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Migrating existing database accounts
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Migrating existing database configuration
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Migrating existing database networks
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Migrating existing database routes
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Migrating existing database hosts
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Action: /etc/e-smith/events/nethserver-shellinabox-update/S00initialize-default-databases SUCCESS [0.13208]
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: expanding /etc/sysconfig/shellinaboxd
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: expanding /etc/httpd/conf.d/shellinabox.conf
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Action: /etc/e-smith/events/actions/generic_template_expand SUCCESS [0.116091]
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: [INFO] service shellinaboxd restart
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Stopping shellinaboxd: [ OK ]#015
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Starting shellinaboxd: [ OK ]#015
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: [INFO] shellinaboxd restart
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: [INFO] service httpd reload
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: Reloading httpd:
Oct 18 15:26:44 nethserver-dev esmith::event[3756]: [INFO] httpd reload
(END)
the event hangs, until I do a ctrl+C
I have had a similar issue with transmission, I tricked the problem by using an action which was here to restart the service and do the adjust-services, but this time I would understand why instead of turn around the ‘bug’
When I remove the shellinaboxd link to restart, then the event doesn’t hang anymore
Where I can look please ?
This kind of problem is often caused by the daemon itself which doesn’t correctly close all file descriptors.
I suggest you try using an upstart job.
Create a template-metadata /etc/e-smith/templates.metadata/etc/init/shellinabox.conf
with something like this:
TEMPLATE_PATH='upstart-job' OUTPUT_FILENAME='/etc/init/shellinabox.conf' MORE_DATA={ name => 'shellinaboxd', description => 'Shellinabox daemon', author => 'Your name ', daemon_bin => '/usr/sbin/shellinaboxd', daemon_args => '', respawn => 1, 'expect' => 'fork', stop_on => 'stopping network', start_on => 'started network' }
See /etc/e-smith/templates.metadata/etc/init/httpd-admin.conf
for an example.
Upstart doesn’t like shellinaboxd
Oct 19 17:04:55 nethserver-dev esmith::event[4905]: Event: nethserver-shellinabox-update
Oct 19 17:04:55 nethserver-dev esmith::event[4905]: Migrating existing database accounts
Oct 19 17:04:55 nethserver-dev esmith::event[4905]: Migrating existing database configuration
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database networks
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database routes
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database portforward
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database fwservices
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database hosts
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database fwrules
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Migrating existing database tc
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Action: /etc/e-smith/events/nethserver-shellinabox-update/S00initialize-default-databases SUCCESS [0.129099]
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: expanding /etc/sysconfig/shellinaboxd
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: expanding /etc/init/shellinaboxd.conf
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: expanding /etc/httpd/conf.d/shellinabox.conf
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Action: /etc/e-smith/events/actions/generic_template_expand SUCCESS [0.132511]
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: shellinaboxd start/running, process 4914
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: [INFO] shellinaboxd has been started
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: [INFO] service httpd reload
Oct 19 17:04:56 nethserver-dev init: shellinaboxd main process ended, respawning
Oct 19 17:04:56 nethserver-dev kernel: __ratelimit: 1 callbacks suppressed
Oct 19 17:04:56 nethserver-dev kernel: shellinaboxd[4913]: segfault at 2 ip 00007fda6dca7e2c sp 00007fff600b7d50 error 4 in libc-2.12.so[7fda6dc60000+18a000]
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Reloading httpd:
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: [INFO] httpd reload
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Action: /etc/e-smith/events/actions/adjust-services SUCCESS [0.358138]
Oct 19 17:04:56 nethserver-dev esmith::event[4905]: Event: nethserver-shellinabox-update SUCCESS
Oct 19 17:04:56 nethserver-dev kernel: shellinaboxd[4938]: segfault at 2 ip 00007f12e485fe2c sp 00007ffe0207b170 error 4 in libc-2.12.so[7f12e4818000+18a000]
Oct 19 17:04:56 nethserver-dev kernel: shellinaboxd[4951]: segfault at 2 ip 00007f7ecf0d7e2c sp 00007ffcfff73830 error 4 in libc-2.12.so[7f7ecf090000+18a000]
Oct 19 17:04:57 nethserver-dev kernel: shellinaboxd[4956]: segfault at 2 ip 00007fa10eb4fe2c sp 00007ffff2a240f0 error 4 in libc-2.12.so[7fa10eb08000+18a000]
Oct 19 17:04:57 nethserver-dev init: shellinaboxd main process ended, respawning
Oct 19 17:04:57 nethserver-dev kernel: shellinaboxd[4961]: segfault at 2 ip 00007f79d4b4fe2c sp 00007fffefb79790 error 4 in libc-2.12.so[7f79d4b08000+18a000]
Oct 19 17:04:57 nethserver-dev kernel: shellinaboxd[4966]: segfault at 2 ip 00007fd36b97fe2c sp 00007ffdaedee600 error 4 in libc-2.12.so[7fd36b938000+18a000]
Oct 19 17:04:57 nethserver-dev kernel: shellinaboxd[4971]: segfault at 2 ip 00007f0f46dcfe2c sp 00007ffec1d1ca40 error 4 in libc-2.12.so[7f0f46d88000+18a000]
Oct 19 17:04:57 nethserver-dev kernel: shellinaboxd[4976]: segfault at 2 ip 00007f0185d87e2c sp 00007ffcb8983340 error 4 in libc-2.12.so[7f0185d40000+18a000]
Oct 19 17:04:58 nethserver-dev kernel: shellinaboxd[4981]: segfault at 2 ip 00007f6ee3a77e2c sp 00007ffc2bcc4580 error 4 in libc-2.12.so[7f6ee3a30000+18a000]
Oct 19 17:04:58 nethserver-dev init: shellinaboxd main process ended, respawning
Oct 19 17:04:58 nethserver-dev kernel: shellinaboxd[4986]: segfault at 2 ip 00007f008cd0fe2c sp 00007fff2377dd10 error 4 in libc-2.12.so[7f008ccc8000+18a000]
Oct 19 17:04:58 nethserver-dev init: shellinaboxd respawning too fast, stopped
The template.metadata
# cat /etc/e-smith/templates.metadata/etc/init/shellinaboxd.conf
OUTPUT_FILENAME='/etc/init/shellinaboxd.conf'
MORE_DATA={ name => 'shellinaboxd', description => 'Shellinabox daemon', author => 'Stephane de Labrusse <stephdl@de-labrusse.fr>', daemon_bin => '/usr/sbin/shellinaboxd', daemon_args => '', respawn => 1, 'expect' => 'fork', stop_on => 'stopping network', start_on => 'started network' }
this would be great!
the event stops to hang when I redirect the daemon (in the sysvinit script) to /dev/null…argh
- daemon $prog -u $USER -g $GROUP --cert=${CERTDIR} --port=${PORT} --background=$pid $OPTS
+ daemon $prog -u $USER -g $GROUP --cert=${CERTDIR} --port=${PORT} --background=$pid $OPTS >/dev/null 2>&1
I smell a bad written daemon
Discussion is continuing here
