Santé… Salud…cheers
Looks nice!
http://sogo.nu/news/2016/article/sogo-v300-released.html
http://demo.sogo.nu/SOGo/
“Want to try SOGo without installing it? Three accounts are available: sogo1, sogo2 and sogo3. Their password is the same as their username.”
Indeed a realy nice interface. I just tried the demo to have a look around. Anyone knows if it is possible to change the layout (for desktop use) if you don’t want to use the 3 vertical panes? I couldn’t find it…
•horizontal 3-pane view for a better experience on large desktop screens;
But I couldn’t find it either.
Very nice! When can I start my Nethserver update?
Regards
Uwe
Reading the documentation i have the feeling that there’s not so many changes in the configuration files…you should take a vm, install first then upgrade from the sogo repository
[sogo-rhel6]
name=Inverse SOGo Repository
baseurl=http://inverse.ca/rhel-v3/6/$basearch
gpgcheck=0
enabled=0
includepkgs=gnustep-base,libmemcached,libwbxml,sogo*,sope49*
yum --enablerepo=sogo-rhel6 update
http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-3.0.0b5-1.centos6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-activesync-3.0.0b5-1.centos6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-tool-3.0.0b5-1.centos6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-cards-3.0.0b5-1.centos6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-gdl1-contentstore-3.0.0b5-1.centos6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
I suppose that SOGO REPO is broken, because of a new version of packages.
How to change the layout from 3 to 2 vertical panes, but no horizontal panes as it is written here: http://sogo.nu/news/2016/article/sogo-v300-released.html
Maybe is not the latest version on Demo.
They say
it is possible to run both versions 2 and 3 concurrently on the same data set to ease the transition.
…but the package name is “sogo” for both versions. So it’s difficult to install both on the same system… what do you think if we provide SOGo3 starting from ns7 only?
Totally agree!
I always thought mixed thing is not good!
Me too!
Major version updates of packages is not common upstream (read: CentOS does not update major version of apache etc in minor versions of the system).
you are right, the target version is sogo-3.0.0b5-1.centos6.i686.rpm and the version available is sogo-3.0.0-1.centos6.i686.rpm.
It seems they have not renewed the repodata of their repositories
TEST ONLY in a vm, first install nethserver-sogo, then :
yum install http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-activesync-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-ealarms-notify-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sogo-tool-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-appserver-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-cards-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-core-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-gdl1-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-gdl1-contentstore-3.0.0-1.centos6.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-gdl1-mysql-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-ldap-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-mime-4.9-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-sbjson-2.3.1-20160127_1664.el6.1.x86_64.rpm http://inverse.ca/rhel-v3/6/x86_64/RPMS/sope49-xml-4.9-20160127_1664.el6.1.x86_64.rpm
We need time to wait while they update repo
It’s working out of the box on NS 7.
Please try it on a clean 7:
yum --enablerepo=nethserver-testing install nethserver-sogo
It seems good now @Nas
not tested on NS, only on sme, but it is good
