Hi to all,
I’ve some whishes for setting up the backup task over the web frontend.
it would be nice if you can choose what directories you want to backup
also there could be a chance to run a script before and after backup (for example you want to stop a SQL instance before backup and start it again after backup)
change the interval for full backup
customice the rules for deleting old backup (I’m thinking about a switch for days, weeks and month and value from 1 to … you can set)
sending a message after backup with an external mail-server would be nice to
syncing all files and settings to a backup server
These are only wishes but perhaps other people have the same or other wishes too, and something could be realized.
You can already do it, see the notification page.
If you want to use a smart host, simply configure it (in mail server domain on NS 6, and in smart host in NS 7)
Just drop a custom action inside the post-backup-data event
thanks for your good description and the links, it helps a lot.
But it would be nice to do these settings at the webinterface and not at the terminal. It’s not necessary, but for useres coming from a windows gui it’s easeier.
