Good afternoon. I installed the pop3-proxy. There is a problem with sending a letter. Writes a connection error to the SMTP server. Modifications of authorization and other things did not give anything. Ping to server ok. When turn of proxy all is good
Hi Alex,
please have a look in the logs, is there anything? Authentication error or something like that.
You can post the log, so I will have a look at it.
Therefore I write here. I also do not understand why pop3 proxy hinders smtp. I tried all the options with and without authorization. As soon as I disable pop3 proxy mail leaves. When enabled, only pop3 is available. By the way, now I’m just testing. On the server is raised dhcp, web proxy.
Web proxy with authorization AD, mail is personal (mail server on unix, accounts give IPS). I try to set with and without ssl , tls, auto, port 25 and try other port 5**
I honestly never used authenticated mode,
I personally try to put web proxy in transparent mode, enable pop3 proxy, authentication on smtp and port 25.
And see what happens.
Know, however, that I am new to the place. And maybe I have a little “agricultural” advice.
The professionals here are others
I will try to reinstall system step by step and look for it. ISP say that he dont see any attempts to connect to smtp. Mail client is outlook 2013. Mailprovider is same as ISP (mail server on unix, but dont say what exactly)
Install pop3 proxy (not on) - not good (web - ok, mail - pop3 ok, smtp -error)
I dont know, I only install pop3 proxy, dont turn on and have error.
Web proxy - Transparent with SSL
Web filter - filter off, antivirus on
What am I doing wrong?
I only try to use linux system and my knowledge of Linux is not great. I have basic concepts. I can see the configuration files. If you need something else tell me.
