Enzo
(Enzo P)
December 21, 2015, 11:06am
1
Hello,
It is a few days that I can not retrieve messages from my provider for one of my two domains.
This is the error that I find in the log fetchmail:
Dec 21 11:50:02 [err] connection to pop3.xxxxxx.it :pop3 [192.168.1.250/110] failed: Connection refused.
Dec 21 11:50:02 [err] POP3 connection to pop3.xxxxxx.it failed: Connection refused
Dec 21 11:50:02 [info] Query status = 2 (SOCKET)
A while ago I had the same thing happened, I had solved restoring from backup to a few days before, but now does not work either so.
I tried to install a temporary version of Nethserver and everything works (so it is not a fault of my provider).
What can I do?
Thank you in advance
Enzo
giacomo
(Giacomo Sanchietti)
December 21, 2015, 2:33pm
2
Your ISP server is not responding, maybe a temporary problem.
If you want, you can test the connection using netcat: Sensitive Content Warning
Enzo
(Enzo P)
December 21, 2015, 5:55pm
3
Thanks Giacomo,
if I try netcat with nc -v -v pop3.xxxxxx.it 110, from Nethserver I get
nc: connect to pop3.xxxxxx.it port 110 (tcp) failed: Connection refused
but if I try from temporary installation of Nethserver everything works fine and I get
Connection to pop3.xxxxx.it 110 port [tcp/pop3] succeeded!
Something broken in fetchmail?
giacomo
December 22, 2015, 8:58am
4
It’s non fetchmail related.
Check your firewall configuration from the “Firewall rules” page. Also you can check /var/log/firewall.log
Enzo
(Enzo P)
December 22, 2015, 9:37am
5
I don’t think is firewall related, because it isn’t active, furthermore the other domain with very similar parameters working properly.
Look here
Dec 22 10:24:40 [info] 21 messages (21 seen) for aaaaaaaa@yyyyyyyyy.eu at pop3.yyyyyyyyy.eu (136345 octets).
Dec 22 10:24:40 [err] connection to pop3.xxxxxxx.it :pop3 [192.168.1.250/110] failed: Connection refused.
Dec 22 10:24:40 [err] POP3 connection to pop3.xxxxxxx.it failed: Connection refused
Dec 22 10:24:40 [info] Query status=2 (SOCKET)
and
[root@NethServer ~]# nc -v -v pop3.yyyyyy.eu 110 Connection to pop3.yyyyyy.eu 110 port [tcp/pop3] succeeded!
+OK Dovecot ready. ecc.
quit
+OK Logging out
[root@NethServer ~]# nc -v -v pop3.xxxxxx.it 110 nc: connect to pop3.xxxxxx.it port 110 (tcp) failed: Connection refused
zamboni
(Stefano)
December 22, 2015, 10:02am
6
it’s likely a policy on target machine… ISP don’t like you poll their servers too often
in the past, when fetchmail was the only way to catch email form ISP, some users wanted to poll external server every minute… and that’s bad
Enzo
(Enzo P)
December 22, 2015, 10:09am
7
I try to poll every 10 minutes (from 5).
I will keep you informed
Sorry if it may seem obvious: please, ask your ISP.
Enzo
(Enzo P)
December 22, 2015, 11:55am
9
I’ve already asked, and they say that on their part is all right
Nas
(Artem Fedai)
December 22, 2015, 12:59pm
10
@Enzo
make traceroute to this host and share it pls
zamboni
(Stefano)
December 22, 2015, 4:06pm
11
well, obviously on their side is all ok
they can use some bandwidth policies to save resources, so if your client gets a “connection refused” error, it’s not an issue on their side…
Enzo
(Enzo P)
December 31, 2015, 12:32pm
12
THANK YOU Artem,
you pointed me in the right direction.
A traceroute to my pop3 address receiving the response only from my local IP address (192.168.1.250).
So I checked the /etc/host file, and I found:
192.168.1.250 NethServer.xxxxxx.it NethServer smtp.xxxxxx.it imap.xxxxxx.it pop.xxxxxx.it pop3.xxxxxx.it
After removing the last two entries everything works fine.
But the file header say:
================= DO NOT MODIFY THIS FILE =================
Manual changes will be lost when this file is regenerated.
So, what do I do now?
Go to server-manager, DNS and delete the pop3 host (anr/or any relevant host).
Enzo
(Enzo P)
December 31, 2015, 4:22pm
14
Thanks Filippo,
I had already looked at, but as you can see was, and it is, empty
Please, look into the “Alias server” tab.
Nas
(Artem Fedai)
December 31, 2015, 6:28pm
17
Dears,
config show postfix
postfix=service
**MxRecordStatus=enabled**
cat /etc/e-smith/templates/etc/hosts/01mx_record
# 01mx_record -- push smtp, imap, pop, pop3 aliases
# Add DNS aliases only if acting as resolver:
use NethServer::Service;
my $s = new NethServer::Service('dnsmasq');
if( $s->is_owned() && $s->is_enabled() && $postfix{MxRecordStatus} eq 'enabled') {
push @hostnames, map { join('.', $_, $DomainName) } qw(smtp imap pop pop3);
Run :
db configuration setprop postfix MxRecordStatus disabled
signal-event nethserver-mail-common-update
Nas
(Artem Fedai)
January 3, 2016, 8:10pm
18
Hi @giacomo @filippo_carletti ,
Why do we need this records in /etc/hosts , maybe it is better to let the people choose these records in DNS Section ?
Enzo
(Enzo P)
January 4, 2016, 9:14am
19
Thanks Artem,
after your fix my hosts file it’s correct.
Thanks again and best wishes for the New Year to everyone.
Ciao
Enzo
