Hello everyone openvpn now goes, run boot system and now all right, what do I do now and associate nethserver a win2008 AD, in fact, see the server in the AD resources to win2008 but vpn users are authenticated.
My goal is to create a vpn server with nethserver and place to win2008 AD to use existing users on the domain.
Thank you.
P.S. This is an on-line translation
Sorry but you can’t use users from AD to authenticate inside the VPN.
You can not, it is difficult to realize?
It’s not hard, it’s a nightmare Every time you have to deal with and AD is hell
@Vinny74 just install openvpn-auth-ldap.x86_64 from Epel repo
modify files below :
/etc/openvpnhost-to-net.conf
plugin /usr/lib64/openvpn/plugin/lib/openvpn-auth-ldap.so “/etc/openvpn/auth/ldap.conf”
URL ldap://example.local
BindDN CN=openvpn,CN=Users,DC=example,DC=local
Password openvpn
Timeout 15
TLSEnable no
BaseDN "DC=example,DC=local"
SearchFilter “(&(sAMAccountName=%u)(memberOf=CN=VPN users,CN=Users,DC=example,DC=local))”
In AD in Users create user openvpn with password openvpn. Create group of users “VPN users”
looks interesting!
realy good feature, if you have existed AD domain.
Great shot!
Just to recap how it works:
- enable the ldap plugin and configure the conf file
- create a general “openvpn” user inside the AD
- add existing users to “VPN users” group to enable openvpn for them
How can we integrate inside the actual implementation?
Would you like to add new fields inside the current UI?
As a side note, please notice that the authentication is passed in clear text to the AD server.
Perhaps OpenVPN supports Kerberos/GSSAPI authentication when connects to AD?
I don’t think so, but it has PAM support.
And no…I don’t want to try try Kerberos AD integration with openldap OpenVPN
…was OpenVPN!
Just to recap how it works:- enable the ldap plugin and configure the conf file- create a general “openvpn” user inside the AD- add existing users to “VPN users” group to enable openvpn for them
Yep, you are right, but if it is existed AD and users has their own group Admin could specify it.
How can we integrate inside the actual implementation?Would you like to add new fields inside the current UI?
I suppose that fields in UI should be as :
ldap uri
cn=user and password
domain and user group
we can always use ldaps, but if it is internal infrastucture why we should use ldaps :)
nas, please, can you use the right tags in your posts? I’m referring to quoting… it’s quite difficult to read your message…
anyway, an old and wise sysadm told me many years ago “trust nobody”… if one of your client is exploited, having auth info in clear text is not a good thing…
I know, but the feature is too cool!!
if you are aimed to security, this is not an option, never
Use ldaps , if you servers in special vlan why do you need ldaps? and how about firewall on windows and you can allow only trusted ip ?
no, nada, niet, nain…
security is another matter
- every clever person has it is own managment vlan between servers and switches
- in case of yours security you forgot about your users (facebook gmail and so on)
- if your users can run sniffers and so on in your system, shame on you !
