davidep
(Davide Principi)
March 29, 2024, 12:04pm
41
So it is Roundcube which has lost the NS8 destination. Let’s verify it. Look at the module destination parameters.
grep MODULE_INSTANCE_ID /var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail/bind.env
Can you see that instance in NS8?
If not, remove the that bind.env file and run
MODULE_NODE_ID=1 ns8-bind-app nethserver-roundcubemail
It selects node 1 as destination, which seems to fit your case.
Then sync again from UI.
danb35
(Dan)
March 29, 2024, 12:07pm
42
[root@neth nethserver-mail]# grep MODULE_INSTANCE_ID /var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail/bind.env
MODULE_INSTANCE_ID=roundcubemail2
I don’t recall having manually installed any instance of Roundcube on this system–should I just delete them both?
dnutan
(Marc)
March 29, 2024, 12:26pm
43
Most surely they come from failed migration attempts. But roundcubemail2 is the actual sync target.
danb35
(Dan)
March 29, 2024, 2:47pm
45
I haven’t, nor have I changed anything as yet. Should I delete those two instances or do anything else first?
davidep
(Davide Principi)
March 29, 2024, 3:24pm
46
davidep:
You replied:
I do not understand if you already did the above steps or not
danb35
(Dan)
March 29, 2024, 3:34pm
47
I ran the grep, it returned MODULE_INSTANCE_ID=roundcubemail2
, and the instance roundcubemail2
exists in NS8 (as does another instance named roundcubemail1
). Because it does exist, I did not remove bind.env nor run the command that followed. And since I hadn’t made any changes, I haven’t retried the sync from the UI.
davidep
(Davide Principi)
March 29, 2024, 3:38pm
48
Ok, understood. Let’s see what is it doing. In NS8 run
runagent -m roundcubemail2 podman ps -a
Look at ps -f -u roundcubemail2
, too
danb35
(Dan)
March 29, 2024, 3:40pm
49
Curious:
root@ns8:~# runagent -m roundcube2 podman ps -a
runagent: [FATAL] Cannot find module roundcube2 in the local node
root@ns8:~# ps -f -u roundcubemail2
UID PID PPID C STIME TTY TIME CMD
roundcu+ 925 1 0 Mar23 ? 00:00:00 /lib/systemd/systemd --user
roundcu+ 946 925 0 Mar23 ? 00:00:00 (sd-pam)
roundcu+ 59274 925 0 Mar23 ? 00:00:00 catatonit -P
roundcu+ 59381 925 0 Mar23 ? 00:00:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd
roundcu+ 268971 925 0 Mar28 ? 00:00:25 /usr/local/bin/agent --agentid=module/roundcubemail2 --actionsdir=/usr/local/age
root@ns8:~#
The runagent
command doesn’t see roundcubemail2
, but the Software Center thinks it’s there:
davidep
(Davide Principi)
March 29, 2024, 3:42pm
50
danb35:
roundcube2
I’m sorry, it’s roundcubemail2
danb35
(Dan)
March 29, 2024, 3:43pm
51
I should have noticed that myself.
root@ns8:~# runagent -m roundcubemail2 podman ps -a
root@ns8:~#
davidep
(Davide Principi)
March 29, 2024, 3:49pm
52
For sure it is not running the rsync daemon!
To fix it,
davidep:
The old instances can be removed. Some modules like Nextcloud, Mail or File Server may require a large amount of disk space and the time of data transfer. In those cases removing the instance and starting again is not really welcome. But for Roundcube and “small” modules it can be acceptable.
It is possible to copy files across volumes, with a low-level cp -a
. However setting permissions to match the subuid/subgid ranges will be a nightmare!
danb35
(Dan)
March 29, 2024, 4:34pm
53
Is it expected that this command would take over an hour to complete? Because it’s been running at least that long with no output or other indication that it’s doing anything.
davidep
(Davide Principi)
March 29, 2024, 4:43pm
54
No, it just installs a new instance of Roundcube and starts rsync daemon…
Images are quite big but it depends on your connection speed!
docker.io/library/mariadb 10.11.5 f3ccb05c76f7 5 months ago 410 MB
docker.io/roundcube/roundcubemail 1.6.6-apache 81bac075e575 2 months ago 715 MB
If you want to check what’s going on, try to run on NS8
ps -f -u roundcubemail3
I suppose the new instance is number 3.
danb35
(Dan)
March 29, 2024, 4:44pm
55
Well, I’d removed the first two instances, so I’d assume it’d be number 1–but neither exists:
root@ns8:~# ps -f -u roundcubemail1
error: user name does not exist
Usage:
ps [options]
Try 'ps --help <simple|list|output|threads|misc|all>'
or 'ps --help <s|l|o|t|m|a>'
for additional help text.
For more details see ps(1).
Usage:
ps [options]
root@ns8:~# ps -f -u roundcubemail3
Usage:
ps [options]
root@ns8:~#
davidep
(Davide Principi)
March 29, 2024, 4:47pm
56
It looks odd… Just to be sure:
grep ^roundcube /etc/passwd
danb35
(Dan)
March 29, 2024, 4:48pm
57
root@ns8:~# grep ^roundcube /etc/passwd
root@ns8:~#
davidep
(Davide Principi)
March 29, 2024, 4:49pm
58
Let’s try to install Roundcube in NS8, in node 1:
time add-module roundcubemail 1
Adding time
to have an idea of the installation speed.
danb35
(Dan)
March 29, 2024, 4:52pm
59
root@ns8:~# time add-module roundcubemail 1
<7>podman-pull-missing ghcr.io/nethserver/roundcubemail:2.0.1
Trying to pull ghcr.io/nethserver/roundcubemail:2.0.1...
Copying blob sha256:f7ee773a577a987ecbd31d195449afcdbc8617fee28146c71567edfbf0011b78
Copying config sha256:9e411d4e317cf6668ac96ddcfaa82e5a1b2ec2a7430ffff51e8314698e7db377
Storing signatures
<7>extract-ui ghcr.io/nethserver/roundcubemail:2.0.1
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/roundcubemail3
ui/css/
ui/css/about~31ecd969.621932db.css
ui/css/app~748942c6.65e859ce.css
ui/i18n/
ui/i18n/de/
ui/i18n/de/translation.json
ui/i18n/en/
ui/i18n/en/translation.json
ui/i18n/es/
ui/i18n/es/translation.json
ui/i18n/eu/
ui/i18n/eu/translation.json
ui/i18n/it/
ui/i18n/it/translation.json
ui/i18n/pt/
ui/i18n/pt/translation.json
ui/i18n/pt_BR/
ui/i18n/pt_BR/translation.json
ui/img/
ui/img/module_default_logo.63a7380d.png
ui/index.html
ui/js/
ui/js/about~31ecd969.8d7e885e.js
ui/js/about~31ecd969.8d7e885e.js.map
ui/js/app~748942c6.591267a6.js
ui/js/app~748942c6.591267a6.js.map
ui/js/chunk-vendors~02576867.44c88c8d.js
ui/js/chunk-vendors~02576867.44c88c8d.js.map
ui/js/chunk-vendors~0605657e.7f254d6a.js
ui/js/chunk-vendors~0605657e.7f254d6a.js.map
ui/js/chunk-vendors~0f485567.baceb456.js
ui/js/chunk-vendors~0f485567.baceb456.js.map
ui/js/chunk-vendors~17faf02d.7f68aab6.js
ui/js/chunk-vendors~17faf02d.7f68aab6.js.map
ui/js/chunk-vendors~1d97ff09.290bda9d.js
ui/js/chunk-vendors~1d97ff09.290bda9d.js.map
ui/js/chunk-vendors~2a42e354.0df57e14.js
ui/js/chunk-vendors~2a42e354.0df57e14.js.map
ui/js/chunk-vendors~2aa62147.38204dba.js
ui/js/chunk-vendors~2aa62147.38204dba.js.map
ui/js/chunk-vendors~41d44f25.e7779fa1.js
ui/js/chunk-vendors~41d44f25.e7779fa1.js.map
ui/js/chunk-vendors~46852254.0b6d19c2.js
ui/js/chunk-vendors~46852254.0b6d19c2.js.map
ui/js/chunk-vendors~57473a66.f586d2ed.js
ui/js/chunk-vendors~57473a66.f586d2ed.js.map
ui/js/chunk-vendors~5bb1f863.3efba861.js
ui/js/chunk-vendors~5bb1f863.3efba861.js.map
ui/js/chunk-vendors~5eba3806.b8428291.js
ui/js/chunk-vendors~5eba3806.b8428291.js.map
ui/js/chunk-vendors~690b702c.fd888ae3.js
ui/js/chunk-vendors~690b702c.fd888ae3.js.map
ui/js/chunk-vendors~7274e1de.dc9fe008.js
ui/js/chunk-vendors~7274e1de.dc9fe008.js.map
ui/js/chunk-vendors~86f6b1bc.cd957566.js
ui/js/chunk-vendors~86f6b1bc.cd957566.js.map
ui/js/chunk-vendors~b5906859.deff14e4.js
ui/js/chunk-vendors~b5906859.deff14e4.js.map
ui/js/chunk-vendors~bc21d4b3.68b10b46.js
ui/js/chunk-vendors~bc21d4b3.68b10b46.js.map
ui/js/chunk-vendors~c8728516.dd1ccc58.js
ui/js/chunk-vendors~c8728516.dd1ccc58.js.map
ui/js/chunk-vendors~d2305125.6a99a4ff.js
ui/js/chunk-vendors~d2305125.6a99a4ff.js.map
ui/js/chunk-vendors~d9886323.1a1a66f6.js
ui/js/chunk-vendors~d9886323.1a1a66f6.js.map
ui/js/chunk-vendors~db300d2f.ddb8641c.js
ui/js/chunk-vendors~db300d2f.ddb8641c.js.map
ui/js/chunk-vendors~ec8c427e.5c1734c3.js
ui/js/chunk-vendors~ec8c427e.5c1734c3.js.map
ui/js/chunk-vendors~fdc6512a.81c5c86c.js
ui/js/chunk-vendors~fdc6512a.81c5c86c.js.map
ui/js/lang-de-translation-json~3c620948.c72dd75f.js
ui/js/lang-de-translation-json~3c620948.c72dd75f.js.map
ui/js/lang-en-translation-json~9b60384d.a038ee89.js
ui/js/lang-en-translation-json~9b60384d.a038ee89.js.map
ui/js/lang-es-translation-json~f7c30340.fba019c1.js
ui/js/lang-es-translation-json~f7c30340.fba019c1.js.map
ui/js/lang-eu-translation-json~8ed4c5c2.1539f90d.js
ui/js/lang-eu-translation-json~8ed4c5c2.1539f90d.js.map
ui/js/lang-it-translation-json~e043826f.e33459c7.js
ui/js/lang-it-translation-json~e043826f.e33459c7.js.map
ui/js/lang-pt-translation-json~45d767f3.e8823e7a.js
ui/js/lang-pt-translation-json~45d767f3.e8823e7a.js.map
ui/js/lang-pt_BR-translation-json~eef7148a.8fbaf25a.js
ui/js/lang-pt_BR-translation-json~eef7148a.8fbaf25a.js.map
ui/metadata.json
ui/shortcuts.json
5d24cc1bda063dc8fae4c337e09e71cc1534c2fac9b5d05f52ea28c7ceca5fe3
{'module_id': 'roundcubemail3', 'image_name': 'roundcubemail', 'image_url': 'ghcr.io/nethserver/roundcubemail:2.0.1'}
real 1m55.191s
user 0m0.507s
sys 0m0.064s
root@ns8:~#
dnutan
(Marc)
March 29, 2024, 4:59pm
60
Partially off topic but…
Numbering only increments (n+1). Probably because it is also used to set a unix user and devs prefer to not re-use them (security reasons, leftovers, complexity determining numeration jumps…). I guess it is stored in Redis.
This also has some downsides when restoring apps from backup, the need to reconfigure related apps…
