Nextcloud problem uploading files
NethServer Version: NethServer release 7.3.1611 (Final)
Module: Nextcloud
How to replicate:
  • Login
  • Try to upload a file bigger than ~ 15KB
The issue you are facing:
Cannot upload files (only small files)
The output of my Nextcloud log in Admin > Logging:
Level	App	Message	Time
Warning	core	Login failed: 'admin' (Remote IP: '192.168.50.34')	2017-07-13T19:25:58-0300
Warning	core	Login failed: 'admin' (Remote IP: '192.168.50.34')	2017-07-13T19:25:43-0300
Fatal	webdav	Sabre\DAV\Exception\BadRequest: HTTP/1.1 400 expected filesize 16384 got 8192
    /usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1129: OCA\DAV\Connector\Sabre\File->put(Resource id #501)
    /usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 513: Sabre\DAV\Server->updateFile('Videos/qqfile', Resource id #501, NULL)
    [internal function] Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
    /usr/share/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
    /usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method PUT', Array)
    /usr/share/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
    /usr/share/nextcloud/apps/dav/appinfo/v1/webdav.php - line 71: Sabre\DAV\Server->exec()
    /usr/share/nextcloud/remote.php - line 162: require_once('/usr/share/next...')
    {main}
	2017-07-13T19:21:14-0300
Error	PHP	fread(): Unable to create temporary file, Check permissions in temporary files directory. at /usr/share/nextcloud/lib/private/legacy/helper.php#296	2017-07-13T19:21:14-0300
The output of your config.php file in /path/to/nextcloud (make sure you remove any identifiable information!):
<?php
$CONFIG = array (
  'passwordsalt' => '',
  'secret' => '',
  'trusted_domains' =>
  array (
    0 => 'localhost',
    1 => 'groupware-test.infoestructura.local',
    2 => '192.168.50.3',
    3 => 'example.com',
  'datadirectory' => '/var/lib/nethserver/nextcloud/',
  'overwrite.cli.url' => 'http://localhost',
  'dbtype' => 'mysql',
  'version' => '12.0.0.29',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbport' => '',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'nextcloud',
  'dbpassword' => '',
  'installed' => true,
  'instanceid' => xxxxxxxx',
  'ldapIgnoreNamingRules' => false,
  'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
Please could you help me?
Thanks in advance!
I think this is your problem. I’ve found this.
Please have a look at it.
Yup, it was. I’ve fixed the problem editing /usr/share/nextcloud/.user.ini file and reading at Installation on Linux — Nextcloud 12 Server Administration Manual 12 documentation
Greetings
