stephdl
(Stéphane de Labrusse)
March 7, 2015, 2:03pm
1
I need feedbacks on a new module I’m working on : nethserver-tt-rss.
yum install http://mirror.de-labrusse.fr/nethserver/nethserver-tt-rss/nethserver-tt-rss-1.0.0-3.ns6.noarch.rpm http://mirror.de-labrusse.fr/nethserver/nethserver-tt-rss/tt-rss-1.15.3-2.ns6.noarch.rpm
normally the service tt-rss (which controls the feed updates) will be started automatically, if you want to control it
service tt-rss start
you can use (start, stop, restart, status)
you can see the internal configuration database
# config show tt-rss
tt-rss=service
MultiUser=enabled
MysqlPort=3306
access=private
status=enabled
once you have modified a property you need to launch a signal-event
config setprop tt-rss status disabled
signal-event nethserver-tt-rss-update
Then you have to go to https://your_ip/tt-rss and use a valid user of your nethserver (can be ‘admin’ if a password is set)
source are available -> http://mirror.de-labrusse.fr/nethserver/nethserver-tt-rss/ and https://github.com/stephdl/nethserver-tt-rss/tree/ns6
Impressive!
Great job @stephdl it works really well on 6.6.
It will take time to review all the code, I quickly noticed an improvement on mysql handling.
Since you’re using the system db, the port prop should be read from the mysqld key:
my $port = $db->get_prop('mysqld','TCPPort')|| '3306';
in /etc/e-smith/templates/usr/share/tt-rss/config.php/10database.
Probably accessing mysqld through a socket would be better.
Then tt-rss db default for MysqlPort should be removed.
I hope that programmers better than me could review your code.
stephdl
March 7, 2015, 3:49pm
3
filippo_carletti:
my $port = $db->get_prop(‘mysqld’,‘TCPPort’)|| ‘3306’;
Yep that can be done, but in fact I thought that if someone would use another instance of mysql on another port, then it will be easier for switching.
Thanks for testing and reviews @filippo_carletti
Uh @stephdl thanks! Really interesting module.
stephdl
April 21, 2015, 5:17pm
5
minor change, see first comment to update
