Nethserver-madsonic needs testers
Ola something new to play with : nethserver-madsonic for NS7
madsonic is a music streamer by a web application -> http://beta.madsonic.org/pages/index.jsp
The application is free during one month, after that if you want to use it on your mobile phone, you must pay. However I use it for free in my browser.
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-madsonic/20161208_madsonic-6.2.9040.rpm http://mirror.de-labrusse.fr/NethDev/nethserver-madsonic/nethserver-madsonic-0.1.1-1.ns7.sdl.noarch.rpm
go to https://YOURIP/madsonic but also before you must let music there by a samba access
the application can be used also by ldap/samba4 AD @dnutan would you please give us the good settings for that, I saw you are good :slight_smile:
you have some db values
[root@NS7DEV7 ~]# config show madsonic
madsonic=service
    MaxMemory=512
    Name=madsonic
    SambaUsers=toto,titi
    TCPPort=4040
    status=enabled
    webaccess=public
for example
config setprop madsonic Name music
signal-event nethserver-madsonic-update
then madsonic is reachable to https://YOURIP/music
A thin panel is available in the configuration area, you can set the web access (private/public), the status (enabled/disabled) and the users allowed in samba share (to manage the media folder). Of course if SambaAD is not installed, samba is in a guest access mode.
Telling the true I don’t know LDAP / AD. So better if someone else checks it or adds a more restrictive LDAP filter.
###OpenLDAP (local account provider)
  • LDAP URL: ldap://127.0.0.1:389/dc=directory,dc=nh
  • LDAP search filter: (uid={0})
  • LDAP group searchBase: ou=groups
  • LDAP group filter: (memberuid={0})
  • LDAP group role attribute: ou
  • LDAP manager DN: cn=ldapservice,dc=directory,dc=nh
  • Password: look for bind password under Status -> Domain accounts, from NethServer’s server-manager.
  • Automatically create users in Madsonic: checked
like me for coding, I crash the code all the time :stuck_out_tongue:
I was able to install and set it up to authenticate from AD, but I get this and http 500 when it process the login and lands in this page:
https://mail.xxxxxxxx.it/madsonic/j_spring_security_check
on the madsonic log I can only see this
[2017-03-19 01:06:34,302] INFO MadsonicLdapBindAuthenticator - cloned from default user ‘jorge’ for DN cn=jorge,cn=Users
Same error here :sweat:
just got it working
i will share a print screen with my settings for AD
The settings that worked for me
able to login! :slight_smile:
@Jorge_Soares @dnutan follow this link http://wiki.nethserver.org/doku.php?id=howto:useful_commands#retrieve_ldap_settings there is a bash command to retrieve all ldap settings, and particularly
“bindPassword” : “secret”,
“bindDN” : “DPNET\VM5$”
like this if you change the password of admin, you don’t need to change it in madsonic.
please, fix the ldap issue at http://wiki.nethserver.org/doku.php?id=madsonic#ldap
version for ns6
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-madsonic/nethserver-madsonic-0.0.1-1.ns6.sdl.noarch.rpm http://mirror.de-labrusse.fr/NethDev/nethserver-madsonic/20161208_madsonic-6.2.9040.rpm
see the first post for settings, no differences
Free Subsonic mobile apps should work with Madsonic server without Premium subscriptions.
I was planning to add MPD to Nethserver, but will try Madsonic first.
Sorry but at the end of your free month, the subsonic app will stop to work, you have to pay.
I love this software :stuck_out_tongue:
In another hand I did a rpm for ampache, but you have to use the web installer, i didn’t make the nethserver integration. See the wiki
released for ns6 and ns7
