Nethserver-fail2ban needs testers
I released a first version of fail2ban, for now there is no gui, but I’m not sure that it is really needed, since it is something which works in the background
I wrote a wiki page -> http://wiki.nethserver.org/doku.php?id=module:fail2ban
Obviously this needs to be tested on real servers exposed to the Internet so look after fail2ban daily :
  • you can look after the administrative emails sent to the admin or custom recipients
  • you can look after the command fail2ban-listban to see the number of banned IP
  • you can look after the command fail2ban-client status to see if fail2ban is running with configured jails
  • you can test the activated jails (do fail2ban-client status and looks after jail name) and try to be banned by fail2ban. IP on your local network cannot be banned except if you set BanLocalNetwork to enabled
when you want to unban an IP do : fail2ban-unban
well I’m looking for your returns, and of course by ideas, new jails, etc
For example Nginx could be more protected, I have just activated the default jails, but we can find more jails on internet.
@stephdl
Thank you for your great contribution :slight_smile:
  1. First command after fresh installation:
    Complete!
    [root@nethserver ~]# config show fail2ban
    fail2ban=service
    ApacheAuth_status=true
    ApacheBadbots_status=true
    ApacheBotsearch_status=false
    ApacheFakegooglebot_status=true
    ApacheModsecurity_status=true
    ApacheNohome_status=true
    ApacheNoscript_status=true
    ApacheOverflows_status=true
    ApacheScan_status=true
    ApacheShellshock_status=true
    BanAction=shorewall
    BanLocalNetwork=disabled
    BanTime=600
    CustomDestemail=
    Dovecot_status=true
    FindTime=600
    IgnoreIP=
    LogLevel=INFO
    Mail=enabled
    MaxRetry=3
    MysqldAuth_status=true
    NginxBotSearch_status=true
    NginxHttpAuth_status=true
    PamGeneric_status=true
    PostfixRbl_status=true
    Postfix_status=true
    Recidive_status=true
    Roundcube_status=true
    Sieve_status=true
    SogoAuth_status=true
    SshdDdos_status=true
    Sshd_status=true
    Vsftpd_status=true
    status=enabled
  2. Signal-events :
    [root@nethserver ~]# signal-event nethserver-fail2ban-
    nethserver-fail2ban-save nethserver-fail2ban-update
  3. Fail2ban commands :
    [root@nethserver ~]# fail2ban-
    fail2ban-client fail2ban-listban fail2ban-regex fail2ban-server fail2ban-testcases fail2ban-unban
  4. Fail2ban Listban :
    sshd Jail
    - Currently banned: 1 - Total banned: 1
    sshd-ddos Jail
    - Currently banned: 0 - Total banned: 0
    List of all banned IP:
    Shorewall 4.6.4.3 Chain dynamic at nethserver.itc-s.net - Sun Dec 20 16:45:17 EET 2015
    Counters reset Sun Dec 20 16:38:26 EET 2015
    Chain dynamic (10 references)
    pkts bytes target prot opt in out source destination
    73 4380 DROP all – * * 223.252.32.73 0.0.0.0/0
5 ) GREAT IT WORKS :slight_smile:
First issue :
When I tap F5 in browser ( 5-6 times or more ) i recive ban :slight_smile:
 apache-overflows Jail
Than i run :
fail2ban-unban my ip
IP was unbanned from shorewall as well , but when we implement WEB-UI we should use :
fail2ban-client set apache-overflows unbanip 38.46.247.229
Becasue fail2ban client still show that this ip is banned and could mislead users.
Wow looking forward to testing it as soon as possibile, in the meantime :+1:
Normally after 600 seconds the ip is unbanned automatically by fail2ban.
You should take a look to the /etc/fail2ban/jail.local and looks after the maxretry specific values for apache
They could be increased or decreased
verified
Fun I tried but without successes, but when I read the /filter.d/apache-overflow.conf I don’t have the feeling that the jail is made to block a host which is doing a huge number of requests. You can verify what occurred in the fail2ban log
I tried with successes sogo-auth, roundcube-auth, pam-generic, vsftpd and sshd
Released since 13 days, with no much returns…this day I’m looking for your inputs…does it work, how much attackers are blocked…etc…etc…etc
For those who have not installed fail2ban, stay cool, your server is under a massive brute force attack and you did nothing :slight_smile:
It works :slight_smile: please implement it in production
You’re right it’s already in my loooong todolist! Hope to have it in the target quite soon.
@nas, can you share the content of : fail2ban-listban
[root@nethserver httpd]# fail2ban-listban
Look after a jail, do : fail2ban-client status {JailName}
Count the number of IP Banned
 apache-auth Jail
 apache-badbots Jail
 apache-fakegooglebot Jail
 apache-modsecurity Jail
 apache-nohome Jail
 apache-noscript Jail
 apache-scan Jail
    - Currently banned: 0     - Total banned: 2
 apache-shellshock Jail
 dovecot Jail
 ejabberd-auth Jail
 mysqld-auth Jail
 pam-generic Jail
 postfix Jail
 postfix-rbl Jail
 recidive Jail
 sieve Jail
 sogo-auth Jail
 sshd Jail
    - Currently banned: 0     - Total banned: 20
 sshd-ddos Jail
I have no production server for now because I work for another company, so it was captured for 2-3 day on my testing server. not so much but it works.
2 or 3 days and you match 20 times for ssh brute force password and two times for apache scanning…good score
[root@nethserver httpd]# uptime
 17:32:02 up 2 days,  2:03,  1 user,  load average: 0.02, 0.01, 0.00
well… nowadays, having 22 tcp exposed to WAN is not smart… :wink:
the first thing to do is to change sshd listening port to something > 1024…
in 15 years I had not a single line in the logs about ssh attacks (only failed logins, but it was me :slight_smile: )
It seems that the main purpose of fail2ban on ssh is to keep ssh port standard and minimize also failed logins, right?
maybe, but changing port will lower (almost) to zero all the problems, meaning that all script kiddies and bots won’t affect you…
obiously a portscan will reveal your real sshd port, but it’s something that can’t be done in a silent way… in this case, fail2ban is a great help
BTW, if only key access is enabled, i.e. no password auth allowed, using a not standard port will let you sleep like a baby
all IMHO
right, with a no root account accepted also, you will live at fort knox…but for other services like apache, postfix, dovecot…and much others, you cannot use non standard ports except if you are alone (or with few known people) to use the server
yeah, sure…
the main difference is that if someone break your server via http, gaining root privileges is quite difficult (using RH/Centos rpm at least), while breaking your ssh account (root anyone?) they already have them :smile:
BTW, everything that can be moved on not standard ports must be moved… the log flooding is a good way to hide many things (for attacker) and to miss the same things (for admin)
I tested fail2ban in lab, failing logins over ssh and imaps: it correctly banned me.
I will ask @giacomo to install it on www.nethserver.org to see how it behaves on the real world.
The only thing I’d like to change it’s Mail=disabled by default. Because I received about 50 email for every started/stopped jail. I know there’s a workaround, but I still hope that fail2ban improves over time and will offer an option to receive emails only for bans (and while at it, disable whois).
Great job @stephdl, thank you.
