All in the topic, you have a wiki page to install it -> http://wiki.nethserver.org/doku.php?id=module:dokuwiki
If you have Ideas or remarks, please shoot.
I put this wiki page in the User guides & Application too.
@vegastech can test, please?
Like it, thanks for your work
I guess that also @Crazyusb may be interested
[SOLVED] Some trouble to install Dokuwiki - #3 by Crazyusb
Hi, since I’ve found a way to install dokuwiki in an ibay it work pretty well, but I will test it on my virtual server when I will have some time
It works like a charm, just a few notes for the wiki page:
I would add a new paragraph after the install phase
And I would add a reference to the dokuwiki manual
What do you think?
Go
yum install http://mirror.de-labrusse.fr/nethserver/dokuwiki/dokuwiki-20150810a-3.ns6.sdl.noarch.rpm http://mirror.de-labrusse.fr/nethserver/nethserver-dokuwiki/nethserver-dokuwiki-0.0.2-1.ns6.sdl.noarch.rpm
Now you can set a document root, use a FQDN domain name. Once set, dokuwiki is reachable at https://toto.com instead of https://toto.com/dokuwiki
