I did a new module, I need feedbacks. it is a module for awstats to analyse web access from your virtualhosts (nethserver-virtualhosts). Of course I need real statistics.
Then either configure a virtualhost with a wordpress or whatever web application you want, it should be workable out of the box for previous virtualhosts.
you will find your awstats configurations in /etc/awstats/awstats.*.conf For now it is minimalist, we could sort some options more, I wait your Ideas
for example we could ignore statistics from lan
you must wait some minutes before to get statististics (default is 5 minutes), you have a web panel in nethgui to modify the settings and browse the domain statistics.
The web statistics pages are protected for the admin user (default), think to set a password. You have a panel to put more users
thank for your interests, you will be surprised by the download statistics. I host a archlinux repository and it is about 5TB (terabyte) for the worse month.
I want to finish this development and I hope to get time to sort a ns6 version.
With the option AWStats Documentation - Configuration directives and parameters we could create statistics, but with the many possibilities of name/software/alias/virtualhost, maybe we could to think something flexible by properties (with a text area in the panel).
With something like that we will create an awstats configuration easily.
Create separate config files for each of the selections
OnlyFiles "^/mylottosite"
OnlyFiles "^/mypersonalsite"
OnlyFiles "^/myetcsite"
I must inspect, probably if i just do some minor change in the way how to write the log, probably i might solve my issue. With sme server the domain name starts first for each line and awstats works well for the ibays.
It is just a matter to say what to log, thanks for the pointers.
I’m away for three days, I will look for it later
