We are proud to announce a new release, NethServer 6.7 ships today!
Download it now!
ISO (500MB) SourceForge - Torrent
Upgrading the previous release
Upgrading from 6.6 is straightforward, check out the Release Notes.
New WebTop Groupware
We have a new full-featured groupware which implements ActiveSync protocol, called WebTop.
PPPoE support
Work on PPPoE support was completed adding such choice into the Multi-Wan configuration panel now, allowing the creation of a new PPPoE provider associated with a free ethernet assigned.
OCSInventory and Adagios
Two fantastic new packages have been released, nethserver-adagios that installs and configures Adagios and nethserver-ocsinventory installs and configures OCS Inventory, moreover a new Monitoring group is available.
IPsec tunnels (net2net) web interface
Now it’s possible to create an IPsec tunnel with devices from other manufacturers or between two NethServer, allowing advanced configuration customization to maximize interoperability and displaying tunnel status in a dedicated page.
DHCP advanced Options
A new custom dhcp options panel was added, now users can pass custom options to client via dhcp.
Restore by WebUI and support of previously installed modules
A simple web interface to restore data from backup is available, the user can now restore from latest backup, select a directory or search for it and restore one or more directory in the original destination or into a new directory. Also in a case of disaster recovery, the configuration backup supports the restore of previously installed modules.
And so much more
These are just the major highlights in 6.7 — there are literally hundreds of other tiny improvements, refinements, and bugfixes in 6.7 that we aren’t covering here, but we’d like to highlight:
- Now you can configure green + red without having to install the firewall module separately
- DHCP on VLANs
- New Tomcat and Postgres packages
- SOGO 2.3.1,
- OwnCloud 7.0.10
- SNMP Support
- Hairping NAT
- NAT 1:1
- SMTP IP based
- Option to specify sender email address of the backup report
- White and blacklist support for the POP3
- Firewall rules support hosts within VPN zone
Thank you
As usual, we’d like to first thank the overall NethServer community for contributions toward this release — whether it was in pull requests, feedback, bug reports and suggestions. In particular, we’d like to highlight significant help in this release from our Testing Team.
Join the NethServer Community
If you like what NethServer is doing, share our project with your friends and colleagues. Help us achieve global equality in access to growth through open source software! For any question or suggestion, signup our community, you are welcome!
