Hello, i configured reverse proxy for a web service published.
Now, if i call my ip from internet, NethSecurity login Page will be loaded.
Is possibile to block login to ui from internet, keeping 443 Port open for reverse proxy?
Thank you.
Thank you!
Now i have only nginx page exposed.
Reading docs, i noticed that ui Is on 9090 port too, like NS7.
My opinion is that ui can be turned off on 443 by default and show a welcome page like NS7 or nothing.
Would be great this option is in webgui available to switch it in or off
This could be done, but usually is simpler for a user which installs the software for the first team reaching the port 443 rather then 9090. Also 443 is the default of OpenWrt, so OpenWrt can feel more at home.
I agree but not so easy to do: you must reconfigure the server where you’re connected, it’s not simple to handle the full workflow from the UI.
