Continuing the discussion from Introducing new members on community - 22 Feb 16:
Splitted from the welcome topic
Hi @flatspin ,
Can you please share your network configuration page, in order to help you completely.
Hi @Nas ,
thank you for your reply. I solved the problem allready. I just changed wirings. Then everything went fine.
Fortunately I had an old wire directly to the router, so I didn’t have to use the switch. I pluged in that cable an
everything was o.k. I’m affraid I did a “fools firewall”.
I just wanted others to know, so that they are not doing the same mistake.
