Why not add the possibility to add an IP blacklist?
Manually or by list.
This is a Simple script i originally find on the IPFire forum that i have adapted to work on NS.
In order to make it work i need to add the blacklist option in /etc/shorewall/interfaces
nano /etc/shorewall/interfaces
(in my case)
# Force GREEN + RED mode with only one interface
net eth0 dhcp,nosmurfs,optional
to:
net eth0 dhcp,nosmurfs,optional,blacklist
At the moment (as the script config) the resulting blacklist is of about 15.300 IP.
But you can easly add or remove lists.
Hope this help.
The script:
#!/bin/bash
########## CONFIG
#___________________________
# A firewall blacklist composed from IP lists, providing maximum protection with minimum false positives.
# Suitable for basic protection on all internet facing servers, routers and firewalls.
# includes: bambenek_c2 dshield feodo fullbogons palevo spamhaus_drop spamhaus_edrop sslbl zeus_badips ransomware_rw)
FIREHOL_LEVEL1=1
#____________________________
# An ipset made from blocklists that track attacks, during about the last 48 hours.
# (includes: blocklist_de dshield_1d greensnow openbl_1d virbl)
FIREHOL_LEVEL2=1
# An ipset made from blocklists that track attacks, spyware, viruses.
# It includes IPs than have been reported or detected in the last 30 days.
# (includes: bruteforceblocker ciarmy dragon_http dragon_sshpauth dragon_vncprobe dshield_30d dshield_top_1000
# malc0de maxmind_proxy_fraud myip openbl_30d shunlist snort_ipfilter sslbl_aggressive talosintel_ipfilter zeus vxvault)
FIREHOL_LEVEL3=1
# An ipset made from blocklists that track attacks, but may include a large number of false positives.
# (includes: cleanmx_viruses blocklist_net_ua botscout_30d cruzit_web_attacks cybercrime haley_ssh
# iblocklist_hijacked iblocklist_spyware iblocklist_webexploit ipblacklistcloud_top iw_wormlist malwaredomainlist)
FIREHOL_LEVEL4=0
# A web server IP blacklist made from blocklists that track IPs that should never be your web users.
# (This list includes IPs that are servers hosting malware, bots, etc or users having a long criminal history.
# This list is to be used on top of firehol_level1, firehol_level2, firehol_level3 and possibly firehol_proxies
# or firehol_anonymous) . (includes: hphosts_emd hphosts_exp hphosts_fsa hphosts_hjk hphosts_psh hphosts_wrz
# maxmind_proxy_fraud myip pushing_inertia_blocklist stopforumspam_toxic)
FIREHOL_WEBSERVER=0
# An ipset that includes all the anonymizing IPs of the world. (includes: anonymous bm_tor dm_tor firehol_proxies tor_exits)
FIREHOL_ANONYMOUS=0
# An ipset made from blocklists that track abusers in the last 30 days.
# (includes: cleantalk_new_30d cleantalk_updated_30d php_commenters_30d php_dictionary_30d php_harvesters_30d
# php_spammers_30d stopforumspam sblam)
FIREHOL_ABUSERS30D=0
# List of ip related to advertising and tracking
YOYO_ADLIST=1
# EmergingThreats.net Command and Control IPs These IPs are updates every 24 hours and should be
# considered VERY highly reliable indications that a host is communicating with a known and active
# Bot or Malware command and control server
ET_BOTCC=1
# EmergingThreats.net compromised hosts
ET_COMPROMISED=1
##Enable to remove specified ip from list
ENABLE_REMOVING=1
###Change accordingly to your system
BASE="/etc"
FOLDER_BL="sysconfig"
BLACKLIST="$BASE/$FOLDER_BL/blocklist"
WHITELIST="$BASE/$FOLDER_BL/whitelist" #Manually create this file
#___________________________________
rm $BASE/$FOLDER_BL/bl.tmp
rm $BASE/$FOLDER_BL/bl1.tmp
rm $BASE/$FOLDER_BL/b2.tmp
rm $BASE/$FOLDER_BL/blocklist
if [ $FIREHOL_LEVEL1 -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level1.netset -O $BASE/$FOLDER_BL/firehol_level1.tmp
cat $BASE/$FOLDER_BL/firehol_level1.tmp > $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_level1 %s \n" `cat $BASE/$FOLDER_BL/firehol_level1.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_level1.tmp
fi
if [ $FIREHOL_LEVEL2 -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level2.netset -O $BASE/$FOLDER_BL/firehol_level2.tmp
cat $BASE/$FOLDER_BL/firehol_level2.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_level2 %s \n" `cat $BASE/$FOLDER_BL/firehol_level2.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_level2.tmp
fi
if [ $FIREHOL_LEVEL3 -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level3.netset -O $BASE/$FOLDER_BL/firehol_level3.tmp
cat $BASE/$FOLDER_BL/firehol_level3.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_level3 %s \n" `cat $BASE/$FOLDER_BL/firehol_level3.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_level3.tmp
fi
if [ $FIREHOL_LEVEL4 -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level4.netset -O $BASE/$FOLDER_BL/firehol_level4.tmp
cat $BASE/$FOLDER_BL/firehol_level4.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_level4 %s \n" `cat $BASE/$FOLDER_BL/firehol_level4.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_level4.tmp
fi
if [ $FIREHOL_WEBSERVER -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_webserver.netset -O $BASE/$FOLDER_BL/firehol_webserver.tmp
cat $BASE/$FOLDER_BL/firehol_webserver.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_webserver %s \n" `cat $BASE/$FOLDER_BL/firehol_webserver.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_webserver.tmp
fi
if [ $FIREHOL_ANONYMOUS -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_anonymous.netset -O $BASE/$FOLDER_BL/firehol_anonymous.tmp
cat $BASE/$FOLDER_BL/firehol_anonymous.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_anonymous %s \n" `cat $BASE/$FOLDER_BL/firehol_anonymous.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_anonymous.tmp
fi
if [ $FIREHOL_ABUSERS30D -ne 0 ]; then
wget -t 3 --no-verbose https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_abusers_30d.netset -O $BASE/$FOLDER_BL/firehol_abusers_30d.tmp
cat $BASE/$FOLDER_BL/firehol_abusers_30d.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in firehol_abusers_30d %s \n" `cat $BASE/$FOLDER_BL/firehol_abusers_30d.tmp | wc -l`
rm $BASE/$FOLDER_BL/firehol_abusers_30d.tmp
fi
if [ $YOYO_ADLIST -ne 0 ]; then
wget -t 3 --no-verbose "http://pgl.yoyo.org/adservers/iplist.php?ipformat=plain&showintro=0&mimetype=plaintext" -O $BASE/$FOLDER_BL/yoyo_ad.tmp
cat $BASE/$FOLDER_BL/yoyo_ad.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in YOYO_ADLIST %s \n" `cat $BASE/$FOLDER_BL/yoyo_ad.tmp | wc -l`
rm $BASE/$FOLDER_BL/yoyo_ad.tmp
fi
if [ $ET_BOTCC -ne 0 ]; then
wget -t 3 --no-verbose "https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/et_botcc.ipset" -O $BASE/$FOLDER_BL/et_botcc.tmp
cat $BASE/$FOLDER_BL/et_botcc.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in ET_BOTCC %s \n" `cat $BASE/$FOLDER_BL/et_botcc.tmp | wc -l`
rm $BASE/$FOLDER_BL/et_botcc.tmp
fi
if [ $ET_COMPROMISED -ne 0 ]; then
wget -t 3 --no-verbose "https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/et_compromised.ipset" -O $BASE/$FOLDER_BL/et_compromised.tmp
cat $BASE/$FOLDER_BL/et_compromised.tmp >> $BASE/$FOLDER_BL/bl.tmp
printf "\n Amount of lines in ET_COMPROMISED %s \n" `cat $BASE/$FOLDER_BL/et_compromised.tmp | wc -l`
rm $BASE/$FOLDER_BL/et_compromised.tmp
fi
printf "\n Amount of lines in the combined blocklist before any cleanup is done %s \n" `cat $BASE/$FOLDER_BL/bl.tmp | wc -l`
printf "\n Remove comments etc."
cat $BASE/$FOLDER_BL/bl.tmp | sort | uniq > $BASE/$FOLDER_BL/bl1.tmp
sed /#/d $BASE/$FOLDER_BL/bl1.tmp > $BASE/$FOLDER_BL/bl2.tmp
if [ $ENABLE_REMOVING -ne 0 ]; then
### use this to remove ipadress or range from the blocklist (if needed)
### Add ip(s), one per line, in $BASE/$FOLDER_BL/whitelist
awk '{if (f==1) { r[$0] } else if (! ($0 in r)) { print $0 } } ' f=1 $BASE/$FOLDER_BL/whitelist f=2 $BASE/$FOLDER_BL/bl2.tmp > $BASE/$FOLDER_BL/blocklist
else
mv $BASE/$FOLDER_BL/bl2.tmp > $BASE/$FOLDER_BL/blocklist
fi
printf "\n Amount of lines in final blocklist %s \n" `cat $BASE/$FOLDER_BL/blocklist | wc -l`
rm -rf /etc/shorewall/blacklist
cp $BASE/$FOLDER_BL/blocklist /etc/shorewall/blacklist
shorewall refresh &>/dev/null
UPDATE:
Thanks to Giacomo, in order to make the edit at the shorewall config persistend do this:
mkdir -p /etc/e-smith/templates-custom/etc/shorewall/interfaces/
Then add this code to /etc/e-smith/templates-custom/etc/shorewall/interfaces/20nics
# 20nics
use esmith::NetworksDB;
my $ndb = esmith::NetworksDB->open_ro();
my $mac_validation = $firewall{'MACValidation'} || 'disabled';
my $mac_option = '';
if ($mac_validation eq 'enabled') {
$mac_option = ',maclist';
if (!defined($ndb->red)) {
foreach my $i ($ndb->green) {
my $role = $i->prop('role') || next;
my $type = $i->prop('type') || '';
next if ($role eq 'slave' || $role eq 'bridged' || $role eq 'pppoe');
next if ($type eq 'alias');
if ($role eq 'green') {
$OUT .= "# Force GREEN + RED mode with only one interface\n";
$OUT .= "net\t".$i->key."\tdhcp,nosmurfs,optional,blacklist";
$OUT .= ",bridge" if ($type eq 'bridge');
$OUT .= "\n";
} else {
foreach my $i ($ndb->interfaces) {
$OUT .= "loc\t".$i->key."\tdhcp,nosmurfs,routeback".$mac_option;
} elsif ($role eq 'red') {
$OUT.="net\t".$i->key."\tdhcp,nosmurfs,optional,blacklist";
} else {
$role = substr($role,0,5); #truncate zone name to 5 chars
if ($role eq 'blue') {
$OUT.="$role\t".$i->key."\tdhcp,nosmurfs,routeback".$mac_option;
} else {
$OUT.="$role\t".$i->key."\tdhcp,nosmurfs,routeback";
$OUT .= "\n";
UPDATE1:
Added Ransomware blocklist , readded yoyoadlist
UPDATE2:
Complete Rewrite, changed blocklist (Thanks to firehol)
Create the whiteliste file if needed
UPDATE3:
Added 2 blocklist ET_BOTCC and ET_COMPROMISED
