Hello I would be interested to configure and install the plugin modules on nethserver
Have some guidance
thank you
Do you want to install DPI module?
yes i need to install dpi module
You have to go in “Software Center” and search DPI… Click “Install”.
Then when you create Firewall Rules you can choose as Service one of the category in DPI list and block traffic (drop o reject).
http://docs.nethserver.org/it/latest/firewall.html?highlight=dpi
Thanks for the help but in my nethserver I can not select in any one
Service on the dpi list
What kind of Nethserver Version have you got?
Versione sistema:NethServer release 7.3.1611 (Final)Versione kernel:3.10.0-514.21.2.el7.x86_64
I have the same.
If you want give me remote access…
oki please give me a email for remote access on my nethserver
Please keep us updated, we want to know what issue was
Just try:
yum install nethserver-ndpi
Then check the module is loaded:
lsmod | grep xt_ndpi
