NethServer Version: 7
Module: your_module
Hello,
I did install erpxe on my centOs and nethserver 7, and I have 2 cards, just like this topic : http://community.nethserver.org/uploads/db8506/_optimized/626/38d/0fc97f8b74_541x500.png
Here is my configuration
ifconfig
enp5s10: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::250:fcff:fe46:16c9 prefixlen 64 scopeid 0x20
ether 00:50:fc:46:16:c9 txqueuelen 1000 (Ethernet)
RX packets 128 bytes 43776 (42.7 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 312 bytes 32082 (31.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp63s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.31 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::219:bbff:fedf:413a prefixlen 64 scopeid 0x20
inet6 2a01:e34:ee2a:2750:219:bbff:fedf:413a prefixlen 64 scopeid 0x0
ether 00:19:bb:df:41:3a txqueuelen 1000 (Ethernet)
RX packets 106 bytes 13272 (12.9 KiB)
TX packets 108 bytes 42110 (41.1 KiB)
device interrupt 17
So I put enp5s10 on green, and enp63s0 on red because the adress is given by the internet box.
When I read the documentation (http://docs.nethserver.org/en/latest/dhcp.html) I do not exactly understand what range of IP (or static IP) I must put on enp5s10, which must be the DHCP server for ERPXE…
Can you help me ?
Thanks !
