Help setting up a reverse proxy on nethserver
Hi Guys
i was Wondering if i could get some help setting up a reverse proxy on nethserver. i am trying to setup external access to some internal web servers with out breaking sogo-activesync
regards
Rhys
A first attempt could be adding one or more Apache .conf files under /etc/httpd/conf.d. This is an Apache configuration task: NethServer almost does not care of what is inside that directory.
thanks buddy I will give that ago so other then that it should be the same as regular apache
Regards
Rhys
hi buddy
is their a httpd.conf to edit from what i have seen i need to edit that in apache instructions i have found. im trying to achieve access to transmission and phpvirtualbox with out having add ports
sorry for being a Noob im still learning unix
regards
rhys
still having no luck anybody able to help with the httpd.conf
regards
rhys
take a look here for an example:
https://www.centos.org/forums/viewtopic.php?t=29485
and, since it’s a apache task, google for
"apache reverse proxy configuration example centos"
find an example that looks like what you need, follow it, try it, and come back with errors and/or doubts (don’t forget to post the link of the howto you followed)
HTH
